    30
    31
    47,040
Assembling the shell
Deb
With all the windows installed and the door frames in place, I was ready to assemble the shell. The Magnolia has an interlocking design, so there’s a specific order for assembly.
First I put the center partition in place on the first floor. It slides into a slot on the first floor.
Then I added the front door section which also slides into a slot on the first floor:
And then the second floor:
The pole in the center is one I put in place to support the floor while I assembled the house. I don’t like floppy floors while I’m putting up walls.
Next, I put on the center section of the front bay window. It adds additional support for the floor while I work with the rest of the bays.
I’m a little bit challenged when it comes to bays. No matter how careful I am, I always end up with gaps. But I have discovered that the following process does reduce the amount of gaps for me.
I install the center piece of a bay first:
Then I put on the sides:
After the bays were on, I installed the other wall.
Now that the main walls are in place, I can work on the interior of the first floor. As I mentioned, I have challenges with gaps in the bays, so I learned from Nutti about using bamboo skewers to cover the joins. Not only does it cover any gaps, but I think it is a lovely finished look and a nice architectural finish. On some houses, I overlap the wallpaper on the interior joins of a bay, but in this house, I wanted the woodwork to really stand out and “pop” the wallpaper. So on the interior of the bays, I installed bamboo skewers cut to size and painted to match the rest of the woodwork. I think it really defines the shape of the bay in this house.
While the paint was drying on the skewers, I cut basswood strips for baseboards and painted them to match. The baseboards continue thru the entire house around all the lower edges. I like that finished look in a mini house. In some houses, I use a 3/4 round moulding, but in this house, a more defined look was appropriate so I used simple basswood strips.
1 Comment
Hello, Deb,
I realize it's been 13 years since you completed The Magnolia, however, I did have a question. It looks like you plced the windows into the walls before putting the structure together. My questions are:
1) Did you do a 'dryfit' of the house first?
2)After the dryfit, did you complete the windows and install?
3)After windows installed, you began putting the house together with glue?
Deb, I'm so new at this and have had my house pieces just sitting in their box. I've labeled everything and made sure we have everything. But this is a daunting task for me. I've asked about different things on the blog, think I ticked off one person (which I didn't mean to do) and now, I'm just trying to figure out how to proceed.
Thanks in advance for your advice!
Carolyn Robinson
