    2
  • comment
    1
    3,883
Building a Sofa
minime
Building a Sofa
I am using 1/8” plywood because I have plenty on hand and this will make a sofa sturdy enough kids to use. Cardboard, foam core or thicker plywood could be substituted with minor adjustments. Several of my parts will be built up to the thickness that I need. I am also making the cushions out of plywood. I use a utility knife to cut my parts. Three or four scores and I’m through it.
I chose a style that has straight lines and looks fairly simple. Please go the the La-Z-Boy site and look for the Dexter to see my choice.
Using my own real life sofa for dimensions and the picture as my guide I came up with a parts list. I’m going to make this as a loveseat so it won’t be quite as long as the one pictured.
Parts List
Body
2 Backs 4 1/2” X 2 1/2”
4 Ends 3” X 1 1/2”
1 Bottom 4 1/2” X 11/16”
1 Seat 4 1/2 “X 2 3/4”
1 Front 4 1/2” X 1/2"
Cushions
6 Backs 2 3/16” X 1 3/4”
4 backs 1/4” X 2 3/16”
6 Bottoms 2 3/16” X 2 13/16”
Using yellow wood glue I glued the two backs together with the best sides on the outside. The same with the ends, two sets of two. This makes each of the three pieces 1/4” in real size or 3” in 1:12 inch scale size.
There are two bottom cushions, built up to three pieces, making them 3/8” in real or 4 1/2” in scale. I wanted a slight slant for the back so I glued 2 pieces then I put in two 1/4” pieces and added the third piece. I used gorilla glue at the top.
After giving them plenty of time to dry I glued the ends to the back and bottom using gorilla glue.
Again, waiting for it to dry, I used gorilla glue on the front and I glued a popsicle stick on the back to hold the seat at the right height when it goes on.
I then glued the seat on using gorilla glue.
I trimmed off the gorilla glue and sanded a little so that my surfaces would be smooth.
All I need now to do now is upholster and add legs, it looks pretty good so far.
The reason I use gorilla glue on the body is because I feel it is a lot stronger and it is easier to remove the excess when dry.
I have already finished this particular sofa but don’t have pictures of the upholstering process. Within the next couple of days I will be doing another one and will blog the upholstering at that time. If you have any questions please feel free to ask.
Still doesn’t have legs!!
1 Comment
I know that this is going over your sofa info(which is great I may add) but you were nice enough to try and send me a link to web sites to hook together the light house and light keepers house. the links never came up. would you be so kind as to email them to me at paceus@aol.com
