Building the Vineyard Cottage
I've decided to build the Vineyard Cottage. It's a very pretty house. I can't decide if I want to put it in the diningroom in Charlotte or the Guestroom here in Maiden, but either way the colors I want to use will work in either room.
As usual, I have started with staining my floors. I've gone with a darker stain because I want to use bold colors on this house.
Believe it or not, I actually dry fitted this house to see how things went, which is something I don't usually do.
Then I started gluing the house together. I still like using wood glue, but I've borrowed a little trick that I picked up from Rik Pierce's classes. I use a bit of superglue on the wood glue to get an instant bond while waiting for the wood glue to dry. And I also used my handy dandy special weights--which is anything that I can lay my hands on, LOL! Oh, BTW, I got reminded the hard way that I need to be sure and let glue dry COMPLETELY before running into the house....
I went ahead and painted that inner staircase and railing, since I don't want to get paint on my floors. Once that was dry, I glued in that interior wall and the staircase.
Then I glued the bay side of the house on. I'm amazed at how well this house is going together.
Now the bay side is all nice and dry, and this is how that looks, along with the front wall.
Got the back wall glued on too.
Did a bit of wood putting and glued in the bay window. I had to go ahead and paint where that bay was going because I knew that once the bay was in I wouldn't be able to access it too well.
Then I installed the front porch and the other porch side.
And here's where we are tonight.
I'm thinking about doing siding on the house. Not quite sure. I'm still debating wiring it, and I think I may not do that after all. One thing at a time. Perhaps next house I build I'll wire it.
What do you think so far?
Let's see, where were we? Oh yes, I remember now! We're working on SIDING. Which takes FOREVER!!!!! I started with the side of the house, and I have to do it in sections. I also went ahead and put on the window trim, and then vividly remembered why I hate doing it that way, LOL! Of course, I want it that way, so that's the way it's being done.
Of course, you have to put on a little bit of siding, and then let it dry, then work on the next section. Don't you just hate it when the siding curls up like that?
I'm of course using wood glue to put this on. I've discovered that if I put the glue on the siding and then take a brush and evenly distribute the glue on the siding piece, it works a lot better. For me that is. Some of you probably know a better way to do it than I do...
I know exactly how I want this house to look, and I'm just hoping I can pull it off. I'm also still debating whether or not to wire it. Maybe. We'll see.
More pix later!
8 Comments
