Making a Mini Raincoat - Step 4
Make a Mini Raincoat - Step 4
Step 4: Embellish the raincoat with pockets and buttons
That's all there is to it! You're just about finished! Fold up the edges of the sleeves to form cuffs. You can glue them if you like, but they will stay without glue. Embellish the coat with pockets made from scraps and add the buttons to the front.
At this point, you may have to do a little finagling with the cuffs to get them to your desired look, depending if you like wide cuffs or thin cuffs. Also, you may need to trim the bottom of the coat depending on how long you want the coat to be on the doll.
The sleeves will naturally stick up in the air. If you put the raincoat on a doll, the form of the doll will adjust the sleeves accordingly. If you decide to use the coat without a doll, you can glue the arms down at the sides.
You can also leave the hood up or fold it down if you put the coat on the doll. The pictures below show the hood up and down on the doll.
Enjoy your new homemade Miniature Raincoat!
