Holly's Spare Closet Tutorial
Thanks to HavanaHolly for submitting this great tutorial for adding some extra closet space!
Sometimes your dh doesn't have those pesky corners that can be made into closets, and your dh still wants a closet.
Here's how I made a closet for the Laurel. First I took rough measurements of the space where the closet was to go (the rear left corner of the lefthand upstairs room, a bedroom):
Next I cut out the front and side closet walls from foamcore and cut out the doorway and glued the right front wall to the front of the side wall. Then I measured a tongue-blade sized craft stick for a shelf and a 1/8" dowel for the rod, and glued them in and dryfit the closet again to make sure it still fit:
finally I cut another piece of the dowel to fit the doorway and made a curtain for a closet door, since this was a girl's room. I then papered the closet to match the rest of the room (with this paper I didn't get too worked up over it) and when it was dry I installed the curtain and did one last dry fit:
Finally, I glued the closet into place with tacky glue:
and made a little hanger to hold the doll's extra clothes:
