walls all cut
well, i finished cutting the walls today, and dry fit them into place, things were really going well, then i got to the roof panels....my brain hurts now!!!! tough angles, and the edges that need to be beveled are a real problem. they require a 60 degree bevel, but table saws won't cut past about 50. well, i figured a way around it, but it wasn't easy, and not the best method, but after trim and shingles, all will be fine. i also ran into a couple problems with mistakes in the plans, but i corrected those once i did it their way and it didn't work!!! hopefully after my brain gets some rest, i will get back to it tomorrow, with a fresh look at some of these problems. i may not assemble for a while either, due to areas that will be hard to get to after it's assembled. i will no better after i take it apart, and cut all the windows in, then i can see what kind of access i will have to difficult areas.
2 Comments
