    68
    94
    14,920
Trim, Bricks and a Fashion Show....
Debra from Olde Cape Cod
Had another day of randomness! LOL! When I was looking at the pictures of the Neverwas Haul, I noticed that it has copper trim along the roof ridge. At first I was going to order something similar online but then the thrify Yankee in me kicked in and I decided to see what I had kicking around the shop. I've had some plastic wrought iron fencing for years and pulled it out. It looked like one edge would do the trick so I got out my wire cutters to trim away the parts I didn't need. blogentry-3022-0-95004900-1437697370_thu I tried out the pieces on the Summerhouse and I think after they're painted copper they'll be just what I was looking for. blogentry-3022-0-54433000-1437697387_thu Also finished the brick paper on each side of the front bay so that will be the end of pattern making! blogentry-3022-0-15158000-1437697321_thu So I succeeded in knocking over the telescope and knocking the telescope part loose. But, everything else stayed together! Yay! Fixed it and put it up on the shelf where I can't break it. Last I saw, one of the minions was using it to spy on the lady in the McKinley room box... blogentry-3022-0-46709800-1437697415_thu So with the trim taped to the top of the Summerhouse, I then started to tape other pieces on just to see how everything is working together. I was happy with the balance of everything, so took a couple of shots to show you: blogentry-3022-0-23338800-1437697436_thu blogentry-3022-0-43712700-1437697455_thu
The sun peeked out just before starting to set, was nice to see it at last. Have a great evening all!
4 Comments
I have mostly ufo's around here. Only finished ones were contest entries and then I took them apart, not structurally apart, but dismantled and packed up décor, and extraneous parts.
Perhaps you should begin something else while this is still unfinished so the finality won't seem so stark.
I have ufo's too, the skellies have been wanting me to pose them on their motorcycle so that is waiting as well as a hippie bus, Vincent's art studio and a base for the skellie's ride!
