Paint, furniture, and San Fran progress.
Well it has been about a month since I posted last, because of the upgrade; I think I have figu(red out how to post photos (had to put them in an album first), so here goes:
Some exterior paint, finally:
Looking more and more house-y!
Screen door and staircase railing:
Meanwhile, assembling the walls of the San Fran; each wall piece has a little groove that the piece below it slides into. The whole wall assembly turns out to be a bit bendy and flimsy; hopefully it will end up being supported by something. I coated all the glued pieces with sanding sealer per the directions.
Here I am gluing on the 1/4" square rod that will support the floors from the sides:
Here is the foundation:
And here I am splicing the 2nd and 3rd floors together (each floor, like the 1st floor above, consists of two pieces that get butt-spliced together with a thin backer at the seam) and gluing angle-rod to the 3rd floor to support the roof:
Back to the country house: here I am trying to figure out what chair to make for the parlor. Kris' chair at 1inchminisbykris has a footprint that is too big for the parlor, so I went back to my old wing chair design (how I made the wing chair) and fiddled with the design a bit. I found this pic of an old armchair online and I liked the skirt on it (besides I am not good at making furniture legs) so I changed the design to have a solid base so that it could be skirted. I also raised the arms and seat, and changed the back profile a bit.
I used matboard for this prototype, and quickly decided that it wasn't thick enough, so I used a 3/16" foamboard for the pair that I made next:
Then I agonized over the print-- too busy? Too much? Did it go with the wallpaper and flooring? Auuugh! Thinking about other fabrics; at least half of these are too light to work with the carpet however!
So I emailed Mom and asked her what she thought; she said she loved it and it wasn't too much, so I decided to finish them out!
As you can see, I also made another piano from Dada's dollhouse tutorial.
4 Comments
