    302
    199
    249,556
Even more color for the San Fran.
rbytsdy
I went ahead and installed the 3rd floor partition and the little attic floor; I didn't want that long narrow space at the very top, but I didn't want to close it off entirely, so I made a little triangular wall out of foamboard, cut a hole in it, mounted one of the lights behind it, and framed it with a jewelry finding (with a bit of "glazed" translucent scrapbook paper that lets the light out but prevents seeing the nuts and bolts behind it). I also installed the two remaining lights beneath the attic ceiling.
large.IMG_3611.jpg.ef950d150ba6f69384199large.IMG_3612.jpg.df5b7a7db1c1c3a7a1d48
The decorative posts (that hide the vertical partition wall edges) aren't glued in it, just dry-fit until I get all the flooring in.
Figured it was time to get on to the flooring, so I tried something different (I think I saw it on miniature madness blog)-- wood veneer cardstock, that I got from Amazon. I cut it (exacto) into strips, then glued them onto a cardstock template.
large.IMG_3613.jpg.f134d8b1bf3ea6c3bd168large.IMG_3614.jpg.b525da5382aa8e8e41e96
large.IMG_3616.jpg.61d40da39dd38240b9abb
It is pretty good-- have to be careful with it because it is a very thin wood layer over card, but it isn't too fragile. I haven't tried sanding it yet-- will have to proceed with that carefully.
After installing the flooring (upholstery "carpet" in the 2nd floor bedroom), installed the staircases; had to get creative with bracing the partition wall from the other side so as to get a good bond on the staircase side:
large.IMG_3615.jpg.51534b9176d30bd506bfc
large.IMG_3624.jpg.89382fd03a00a6a0f1931large.IMG_3623.jpg.91450668e253f3a631ffa
Oh-- finally finished shingling the front gable! All those pastel-colored shingles remind me of those round tart candies. Glued on the decorative edge trim.
large.IMG_3618.jpg.5e5f83a701e83cc46ec98
Now, about those corbels that you can see on Robin Carey's San Fran at the tops of the window trim sides, that are painted yellow and purple-- I didn't know where to begin looking for them, so I decided to make my own out of matboard and foamboard. I used my dremel to round off the edges of the matboard, and my exacto to bevel the sides of the little foamboard squares.
large.IMG_3617.jpg.8b15536ac8724107aa60alarge.IMG_3619.jpg.f3858f8785083a8e8abab
I'm pretty pleased with how they turned out--
large.IMG_3621.jpg.82356fa735cd4b84eb8d9
Now I'm working on the front railing. If one looks carefully at Robin's house, one can see that the 2nd floor spindles have a slightly different color pattern than the ground floor spindles. :p
large.IMG_3622.jpg.c38619eacc861041f853e
I also put the large trim pieces on the tower; I am planning to make the tower roof removable so it won't be so unwieldy to ship.
large.IMG_3625.jpg.6bfc3a7da62bf7fe0a81e
Need to start thinking about the roof shingles.
3 Comments
