The Glencroft: Day 2-3
Happy Thursday!
Yesterday ended up being a much more productive day than I had previously anticipated. I picked up a couple sheets of foam board and traced and cut out all my sub-walls! Since I thought this would take much longer, I ended up having time to finally start gluing the house together!
I ended up gluing almost the entire front facade. The fireplace wall and staircase will be glued in later after I pre-finish the staircase pieces. (Once glued down, this part will be super hard to reach comfortably) The pictures I attached below were all taken this morning and show the glued together rooms with the sub-walls in place to make sure they fit correctly and look right. You can also see the larger living room and dining room widows. This evening, I plan on starting the paneling in the stairwell area so I can get that segment glued in. Im also expecting my Heidi Ott wall sconces to arrive today as well as a pack of 1/16 basswood to start my paneling. (CANT WAIT!)
I'll update with more photos tomorrow! Cheers!
Chris
- 1
