It's here! Day One.
I was so excited to get this kit. This is one of those kits that can be done MANY different ways. As a matter of fact, I plan on doing two of these. They are Quick to build & easy to Edit.I decided to create a Cave under the house. This house will sit on a Mountain Cliff base. First, I started building the house. I decided I did not like the Window Grids so I cut them out:I decided to create the base by using materials I had on hand. Some people are afraid to use Foam Board because they think it is not sturdy enough. I like it because it is light weight and I can cut it with my hobby knief.I added the walls. It will add another 9 inches to the hieght and 17 inches wide and 11" deep. I used Grill scewers (grocery store item)to add the side walls to the front wall. This will help keep this baase in place while the glue dries. I pushed it in about 3 or four inches and cut the exposed parts off with my east cutter.I then took those Drink Holders you get from Mcdonalds and cut them up and glued them on the base. I also use tape till the glue dried. I used a hot glue gun after a while because this will NOT come off after I am finished. I decided to add stairs to the side of the house I cut seven 2" x 2" (approx.) peices and hot glued them on. The clay and plaster strips with give it extra strength.After looking at this I decided there needed to be an entry way into the base so I cut out a opening:This is the inside so far:Complements of My Mini Shop
2 Comments
