Here is a list of the items needed to do this tutorial!
34 Gauge Gold Beading Wire
Sobo Glue
Knitting needle or Dowel for the size of petal you want
Paint brush for glue (larger)
Paint brush small
Fine Point tweezers for shaping your petals
***Important*** Always twist wire in the same direction! Very Very important
1. Place your dowel in your left hand, spool of wire to the right.
2. Lay the wire in the fr
Supplies
Step 1
Flower Complete, twist stem and remove from tool
Petals Opened up and Flattened
Shaped Petals
You can mix your glue and paint together to paint the petals and leaves. Also paint front and back of the leaves but just paint the front of the flowers. Shape one set of the three petals up and the other set down.
You need to make 2 sets of 3 petals for an Iris. When paint
