Finishing up the last room on the 3rd Floor. I figure this will be like the "honeymoon suite" Installed the floor (which it the same floor I used in the living room)
and figuring out the fireplace in this room. Want to make it somewhat of a cozy and romantic setting. That is memory paper on the inside and outside of the fireplace. Was going to do the eggcrates again but think this looks pretty good.
I'll be putting a mantel on a
Been chuggin away at the interior of the B&B. The owners have really been buggin to get it done by the holidays and they are taking reservations already. Plus I picked up this awesome table to display it on. So far the bathroom is done and as you can see i cut slits into the tile and added spackle to give the floor a ceramic tile look.
and the third floor hallway, I added a skylight here
Then I moved on to the living r
I found this really neat placemat at the dollar store...I figured it would make great bamboo blinds for the beacon kitchen...
Lookie here:
as you can see the kitchen is almost done
The house is starting to look somewhat like a house.
I figure next I have to start priming the interior walls and ceilings. I'm not going to prime the floors because I may stain them or add wood floors with skinny sticks or coffee stirrer sticks. I have both we'll see. I have time because that won't happen until after I add the tapewire. Here is is all primed
I also stained what will be the front porch area
T
Wow it's been awhile since I added anything here . So I've been mostly working on the outside and that is just about almost complete except for the foundation and a few little detail here and there.
I've stained glassed all the window inserts and started installing them. Which I will be doing as I finish each room.
Here's the front door:
I used one of the inserts that was supposed to be for the french w
I am finally able to post some pictures of my progress. (wasn't able to get on this computer) The stairs are almost done, except for the railings on the 2nd and 3rd floor.
I made a runner from some ribbon I picked up a while ago. I thought I would look good with the decor I am thinking of
I made sure that I put the wallpaper up before installing the stairs and I also made some wood panels for the walls to match the stairs. The door will
So I finally started building the Beacon Hill which I won in the October Madness Contest. It took me awhile to get myself started but like always with me once I start I CAN'T STOP! So today is the day. I decided that I wanted to make the kitchen somewhat bigger so a added about 5 inches out the side. I reinforced the floor on the bottom and make a small channel for the wall that would go on later
This is how it looked from the top
I cut s
