Sherr's Blog
    8
    7
    7,970
About this blog
All my mini things
Entries in this blog
Porch in Progress
I've finally managed to work on the entry steps. It's fairly close to the original design but I decided not to baluster the entire way down. The lower steps are now finished (though not in the photo). So far so good. I put my maid with her mop on the steps for scale. And if you look closely you can see the old grumpy man through the window as he dines.
Sherr
Sherr
Making the (Quasi) Georgian Townhouse
Last Thanksgiving I decided to combine my dream of owning an historical property with my 20 year career of designing and drawing houses. I thought I was coming up with a very affordable compromise. I would make it small. If my pocketbook only knew............. With some fundemental cabinetry skills, a workshop full of power and hand tools and access online to the resources and knowledge of many miniature enthusiasts I decided to give it a go! I started with
Sherr
Sherr
Townhouse Continued
After succesfully assembling the house I decided to focus on the interior color scheme. I bought some sample Benjamin Moore colors from the historic collection. The sizes are perfect. The only drawback is the sheen. It tends to be between a flat and an eggshell finish so I ended up buying a quart of semi gloss for the dining and stair halls because it looked better on the woodwork. Still, I really like working with the sample bottles and they are great for general wall color and underneath c
Sherr
Sherr
Townhouse Cont'd. pg 3
I wanted to put some extra attention into the fireplace design but felt the need to save a little money, so I opted out of buying some of the amazing Lawbre and Artisan made fireplaces I saw online and decided to kit bash! I started out with the Miniature House Tidewater Kit and built the basic shell. The resemblance stopped there. I reworked the mouldings and mantle shelf to be a little more substantial and then added some pilasters to the overmantle.
Sherr
Sherr
Towhouse Cont'd. Pg 4
Some of the detail work was more challenging for me. In the living room I decided to hand paint a festoon type motif at the cornice. Tiny brush... huge patience. I would spend more time on it if I had to do it again and maybe explore making a tiny stencil. On the stairs I added brackets under the risers. I cut each one out of 1/16" basswood. I really liked the way they turned out even though you have to look closely to notice them. In fac
Sherr
Sherr
Townhouse Cont'd. Pg 5
I decided to make the master bedroom a much simpler room architecturally. It will have "rough hewn" ceiling beams to hide wiring to the chandelier and the attic lights. The fireplace is plain with delft tiles surrounding the brick firebox and hearth. The window cornices and bed dressings were all made with a pink toile print similar to the dining room. I bought a lace handkerchief in Belgium this summer that I sewed to the white cotton spread to dress it up.The window co
Sherr
Sherr
Townhouse Cont'd. Pg 6
I managed to make a canopy for the cherry poster in the master bedroom. Here is the result. I was very pleased with my first attempt at draping anything mini. It was really trial and error. I pleated the drapes with an accordian file (the kind you organise your bank stubs in!) I can't believe it worked as well as it did. After spraying with lots of starch I lifted the drapes and pinned them into shape on some styrofoam Then made the rest of the parts by gl
Sherr
Sherr
Townhouse Cont'd. Pg 7
Here is the progress so far. The standing seam copper roof is really 1/32" basswood planks w/ upturned spacers painted with liquid copper and then given a patina. I really like the look of it. The chimney was also added with egg carton bricks and a limestone look cap. I will probably make a few chimney pots to top it off.
Sherr
Sherr
