Posts
91 -
Joined
Last visited
Days Won
5
cleojazz last won the day on December 29 2022
cleojazz had the most liked content!
Reputation
22 ExcellentAbout cleojazz
Profile Information
Gender
Female
Location
Ontario
Interests
Music, grandchildren, birding, miniatures,interior decorating, bicycling
Previous Fields
Dollhouse Building Experience
Five or more
Real Name
Gloria
Country
Canada
Recent Profile Visitors
699 profile views
cleojazz commented on cleojazz's gallery image in Members' Gallery
Sorry for taking forever to answer. My real house needed extensive repair after flooding and that has consumed my time. To answer your question, I used Lepage Polystipple, applied with a stiff round brush actually meant for stenciling. But it allowed me to pounce and swirl to get a more authentic look. Cheers!
Thanks, but no. The ones I used came in a single roll, not strips. You had to cut them. They did not tear. And i had to use silicone caulk to attach them. But did they ever look real!
Hi everyone 5 years ago I shingled a house with a roll of real asphalt black shingles. They were not papery at all. More like thin rubber with a rough texture. Does anyone know who sells these? I'm in Canada, but close to Michigan.
Thank you Jennifer! The tile in the bathroom came from Dollarama. It's actually a glass tile, and it was marketed as something to use in scrapbooking. The black and white floor tile came from Lowes. I went to all the local tile stores, looking for inexpensive mosaic type tile. I knew my color scheme and settled on black and white because of the size of the tile center(1")I know 1 foot is a popular tile size, and many tiles for formal areas also come in 2 foot lengths. Many retailers and wholesalers on Ebay from China handle modern furniture. Also try England(Elf miniatures)
Most of the work took a span of 2 years. I had started on just the girl's bedroom , as a room box.A few years went by... it wasn't until I needed a couple surgeries and was housebound that I really started to work at it. And acquiring my husband's aunt's armoire gave me an idea. So my room box became a springboard to the whole condo. Being out of work also changed how I secured furnishings. It became a challenge and a point of pride to 'make something out of nothing'. So I started making furnishings. It was very satisfying work! Glad you like it. Thanks!
I bought some metal tubing at the model train store. It's got a square profile, and about 1/16-1/8th" in size. I measured my actual buffet lamps for height then I cut the tubing proportionately. You have to pass the grain of wheat(or rice) bulb's wires down the tube first, before glueing to a base. The shades took some calculating. I cut a semicircle shape from flocked paper. Here, you'll have to experiment for size. Wrap it around and glue it .To set the shade onto the bulb, I cut a circle from clear plastic,like the kind so many items are packaged in. The circle fits into the shade.You'll secure it with a dab of glue. You need a little hole, big enough to pass the wires through in the plastic circle. The bulb sits just above the hole. How big the circle is affects where it sits inside the shade. It also takes experimenting so your bulb doesn't end up sticking out above the shade.Then I used epoxy to glue it to a tiny flat button for a base. You can either have the wire come out above the base (if they're thin it doesn't show) or you can file or drill out a channel on the button underside, pass the wires through the button's hole, and exit along the channel you carved out. I like the wires that are coated, not wrapped in plastic. They're thinner. Don't use hot glue on these wires...it melts the protective coating off. Your wires could short out. Once you get going, you'll be looking at beads, figurines, all manner of possibilities for lamps. Have fun. Hope this helped.If I get around to making another maybe I'll take pictures.
