chrisatoledo
Platinum Member
  • Posts
    1,467
  • Joined
  • Last visited
  • Days Won
    4
chrisatoledo last won the day on September 7 2016
chrisatoledo had the most liked content!
Reputation
111 Excellent
12 Followers
About chrisatoledo
Previous Fields
    Two
  • Real Name
    CHRIS
Recent Profile Visitors
  1. Thank you so much @Debora59 !! Im thinking of putting it up for sale when its done. To help try to fund the next one haha. I recently started the design phase of my next project!
  2. chrisatoledo
    The Glencroft Dollhouse: Bedroom
    My Finished Glencroft Bedroom. In this room, I didn't make as many drastic changes as I did in the rest of the house but I started with making the window slightly slimmer and taller. For the finishes, prior to assembly, I painted all the ceilings with 3-4 coats of chalk paint which I tinted slightly with Americana Almond. Once dry, I sanded each segment till it was paper smooth and sealed it with Krylon Matte. Once all assembled, I cut and glued in all the beams which I had pre-stained and sealed earlier. I did the calculations and figured out that there was a little over 40 feet total of wood trim in this room! Hope you guys like it! Enjoy! Hugs! Chris
  3. Thank you so much! @havanaholly As far as the floor goes, I used THIS floor paper. Before installing, I sprayed the paper with Krylon Matte to seal it. (I wish I had a satin finish instead of gloss lying around because I really would have loved to see how that looked) After spraying a few coats, I used some water with a few drops raw umber and sponed a few spots around the floors where I knew the fixtures would be. Then sealed again with the Krylon. For the Tank: I fell in love with THIS BATHROOM by Pat and Noel Thomas and loved how they did their tank. I knew that wood would be my base for the tank and I actually found a strip of 2" x 3/4" wood in the dumpster of my building one day that would be perfect! (I can only image what I looked like if any of the neighbors saw me dumpster diving for a piece of wood. haha!) I was mostly excited because I didn't want to have to buy a piece of wood and only use 2 inches of it. So, I eyeballed the height of the tank (I estimate its about 1.75 inches tall) and cut the wood into a small tank sized block. Then came a lot of sanding. I started with a rough 150 grit and worked my way to a 400. I looked at a tank in my house as reference to make sure I smoothed the edges just enough so that it will look like porcelain once it was painted. I added a bevel on both edges to give the tank a little bit of a unique shape but this is totally optional. Once that was all sanded, I glued a piece of 1/8" x 1" basswood on the top of the tank for the lid of the tank and cut it down so it had a 1/16 over hang around the front and sides of the tank, leaving the back flush. I sanded that down to match. The next part is optional but because I wanted to avoid any wood grain, I lightly coated the top, sides and front of the tank with the same resin I used for the tiles and left that to cure for a day. Once that was dry I VERY lightly sanded any dust that might have stuck to the piece overnight so it was smooth. Then I applied the same technique as the rest of the fixtures to simulate porcelain... Sanding, Several Layers of Black Matte Spray Paint, More Sanding, More Black, More Sanding, then a few coats of High Gloss white spray paint (Allowing plenty of time in between to dry....This is crucial. I almost ruined a few pieces being impatient.) You can finish off with a high gloss clear finish but I chose to end at the white. For the handle, I dissected a sink faucet from an extra Chrysnbon kit and used the base and handle of the faucet and pieced them together to form the toilet handle. I had originally used the handle from the pull chain that came with the kit but the scale was way off. To attach, I just drilled a hole at the bottom of the tank (about 1/8 from the front) the same size as the original pipe which I cut down to the right height and just hot-glued the two together. Hope this helps and inspires! Thank you EVERYONE for all the comments! Ya'll give me LIFE! Hugs!
  4. Your so very welcome! The floor paper was purchased here: http://itsybitsymini.com/index.php?main_page=product_info&cPath=1222_160&products_id=2485 PS - I would love to see the finished result when you complete the corner unit!!
  5. That is actually the first reason I thought of using foam-core. I knew I wanted the walls to have some thinckness to them and it ended up being incredibly useful for multiple reasons! As for the tiles, I made them! I actually just posted a tutorial for them last night HERE
  6. I love the look of old subway tiles and when it came to miniature options.....There weren't many. SO, I decided to look into my box of art supplies and see what I can come up with. I had a lot of leftover veneer laying around from my living room walls, so I decided to use this as my base. Im not sure what the results would be but I also thought about using card-stock as the base. The only reason I ultimately went with the veneer was because I decided to use my 4 Inch table saw to uniformly cut it into strips to later cut into individual tiles. Materials I used: • 8"x 5" Wood-Backed Veneer Boards. (This is just two sheets of cheap veneer glued back to back - Purchased HERE) - (Quantity depends on how much space you want to cover. Always make more than you think you need!) • Acrylic Paint - Whatever color you want your tile to be, I used a swiss coffee(off white) color, Almond by Americana, and Black. • EnviroTex Lite Pour-On High Gloss Resin - (I purchased an 8oz set and I still have half the bottles left) - Purchased HERE • Hobby Glue (To Attach) • Dollhouse Stucco/Grout Mix - (I didn't actually use this, but I highly recommend it) Tools I used: • My 4" Mighty-Mite Table Saw • A thick-handled Xacto knife (Easier on the hands) • A LOT of Xacto Blades 1. STEP ONE - First thing I did was prep my veneer boards by sanding them to get them as smooth as possible, finishing with a 400 grit. Once sanded, I used a (very lightly) damp cloth to wipe the boards clean of any remaining saw dust. 2. STEP TWO - I painted a few of the boards with the lighter off-white acrylic paint and another few with black and set to dry. By the time I got to my last board, they were ready for the next coat. For the second coat I went over in the same colors but while the off white boards were still wet, I sponged in a few splotches with the Almond Color Paint by Americana, Making sure to blend in any hard lines. I did this because once I cut the boards into tiles, there would be a slight mis-match of color on some of the tiles. (A common character of old subway tiles) 3. STEP THREE - Once the paint was dry, I mixed up the two part Envirotex Lite Resin and with a one inch wide brush, I painted a even layer on each board. Making sure not to get ANY on the bottom of the boards. (The resin will smooth itself out if applied evenly) You can see the discoloring I did on the boards in the below picture. Disclaimer: Envitotex Lite is a messy product if your not careful. It does not wash off with water and requires paint thinner to clean off. Any container or brush used for application will be unusable after. I set the boards on two strips of wood (Seen in below picture) to dry overnight. (This stuff sets in about 6-8 hours but I recommend leaving it a full day to cure) Try to keep away from an area where dust will be blowing around. . 4. STEP FOUR - The above photos show the cured boards. You can see just how glass-like they set! Once the boards were cured, I set the desired tile thickness on the table saw and cut all the boards into strips. The standard subway tile size is 3"x 6" (1/4" x 1/2" in miniature), But I decided to go slightly bigger. Mostly to save time. You can cut the tiles into whatever thickness you want though. Below photo shows the cut strips. 5. STEP FIVE - Once you have all your strips cut out, its time to start cutting the individual tiles. Before cutting the individual tiles, I would slightly sand both edges of the strips to remove any splinters from the table saw cutting. I cut one tile to the size I wanted and then labeled it "Guide" so it wouldn't get mixed up with the other tiles, and used it to measure out each tile. I did this over a 3 day period because my hands were developing blisters after a while. (This is definitely labor intensive, but the results speak for themselves) How you choose to cut your tile is completely up to you. I just used an Xacto knife because thats all I had, but if you have one of those angled scissors or other form of blade cutting, I suggest trying it. DO NOT use a hand saw to do this. The blade cutting look will give the tile a slight curved edge which makes it look even more like real tile. 6. STEP SIX - Once I had all the tiles cut out, I started laying them down. To glue the tiles, I put down a thin, even line of glue and layed the tiles back to back. I didnt use any spacers because I thought the natural spacing of the tiles looked good. And once I applied the grout, the lines would stand out even more. I used a block of wood at the bottom to keep my tiles straight and then used a small piece of dowel to push my tiles down from above to keep them in a straight line. I used regular hobby glue and then switched to crazy glue at some point because it dried faster. You can use whatever glue you feel works best. Just make sure to keep any glue off the surface of the tiles because cleaning it off will scratch your tiles. • FOR THE TRIM - For the trim tiles, I used a chair rail moulding that I applied the same finishing technique from above, except instead of cutting this into individual tiles i just pressed down with a blade to score the strip. (This made for an easier application as well) The reason I didn't do this for the actual tiles was because I couldn't get the mismatched look if I kept the tiles in strips but since the trim was black, it wouldn't matter. The thin black tile was just a 1/8" wide strip of wood that got the same treatment as well. • GROUTING - I used gray house-paint as grout and I don't recommend this. It was all I had at the time and I had to apply it 4 times to fully fill the cracks.) I recommend using actual dollhouse stucco grout and tinting it. I used gray because it would contrast well and make both the black and white tile pop. END RESULT: PS - Its late and I typed this really fast so I apologize in advance for any Type-os and grammar issues. Enjoy! <3 Chris
  7. Thank you @stickyfingers! I was definitely reluctant to use that floor paper it at first because I wanted something that was textured or embossed to look real but honestly, this was the only tile pattern that matched the style/era/look that I was going for so I decided to try it out. I ended up spraying both sides of it with Krylon Matte spray to seal it, then I lightly sponged some super watered down raw umber paint to create some discoloring and age, then sprayed again with the Krylon Matte to seal. (Im curious how a satin sealer would look, I only had Matte spray on hand but I feel the Satin finish might look more realistic.) I really liked their penny round as well but the hexagon won for me. As far as the tile goes, I made a tutorial page HERE. Thanks again for your wonderful comments! C
  8. Thanks! No extending. The main change I did in this room was drop the ceiling. I didnt want a vaulted ceiling in this room like the bedroom so I used the same foam core board that I made the walls out of to make a dropped ceiling. It also made a great little attic space to hide all the upstairs wiring. I designed the shower to fit like an "L" shape around the roof slant.
  9. Thank you!! Thats a huge compliment! Your Haunted Heritage bathroom was actually a huge inspiration when it came to the details and aging of the fixtures! Thanks again!
  10. Hi Debora! Yes! Before I started assembling the house, I traced every wall on foam-core board. It turned into a complicated puzzle in the end but it was soooooo much easier to do all the finishes and details this way. It also made it easy to cut little channels for all the wiring.
  11. chrisatoledo
    The Glencroft Dollhouse: Bathroom
    Living here in Los Angeles, Ive always loved the "Old Hollywood" architecture of the 1920s. One of my favorite details of this architectural era is the beautiful subway tile you see in the bathrooms. I wanted my bathroom to be completely covered in tile and built-ins! I plan on Kit-Bashing a few pieces of my Chrysnbon Bathroom as well to make it more appropriate to the times. Enjoy!
