CTYankee79
Silver Member
  • Posts
    17
  • Joined
  • Last visited
Reputation
11 Good
About CTYankee79
Previous Fields
    None
  • Real Name
    Kris
Recent Profile Visitors
  1. Love those house of miniatures, lots of unopened boxes from the 70s and 80s for reasonable prices. Polystyrene might be nice too, appreciate the suggestions
  2. Thank you! Are you talking about the kits that Greenleaf sells or are there any other ones you recommend?
  3. Yes! Good reference and thank you! Thank you! I agree about the contrast, my color choices were evolving as I was building, and I realized too late that the colors were too dark/similar. Ok, so I got sidetracked putting together an aquarium, as well as model trains (also both very addicting hobbies), so I’ve been off of dollhouses for a bit...however, my next dollhouse I want one of the Greenleaf laser cuts, either the Tennyson or the Jefferson. I also like the RGT New England Colonial line. So it will be one of those 3!
  4. Thanks! Can’t wait to build more thank you holly
  5. Thank you both! I love the Poe portrait too
  6. I always keep a bottle of debonder nearby...if you’re not stuck to anything (except thumb to finger) soak your hands in warm water. I rarely use thin CA glue anymore, that stuff is downright dangerous. I have experience building RC aircraft and they are all laser cut nowadays. Happy to hear that dollhouses benefit from the precision too. Thanks for the input, and it’s good to know about the MDF.
  7. Just finished my first dollhouse, a haunted Orchid. I'm already looking for my next one. There's 3 things I know I want: a laser cut Greenleaf house, a Real Good Toys house, and a colonial house (because I grew up in one). So I'm thinking either the laser cut Jefferson or Tennyson. If I do the Tennyson I would get one of New England colonials from RGT. If I do the Jefferson I would pick a different house from RGT. I want 1" scale. The Orchid was awesome for the price but really took a lot of work to get it finished, a lot of flaws with the wood. I mean what can you expect for the price? So as much as I don't want to spend so much more $ I'm guessing the laser cut and the RGT houses will be a lot easier to assemble and finish, and look that much better. Anybody have thoughts on that?
  8. So it took me quite a while but my first dollhouse is done! Its a haunted Orchid. Still quite a bit of decorating/furnishing/haunting to do but the hard part is done at least. I had worked on it for a few months last fall, put it away, and got it out again this past August. Quite a bit of time but to be fair I barely worked on it some weeks, other weeks I spent close to 20 hours on it. I learned a lot but there are quite a few things I'd do differently for my next dollhouse. I'd like to share what worked and what didn't to get peoples thoughts and opinions. There are definitely some things I should have done prior to assembling the house and there are some things I should have waited to do. It was really tough having the vision to create what I wanted until it was, well, created. So I mulled and pondered and researched and planned all the colors and decisions I had to make but started getting discouraged, so I said I'm just going to work on this step by step and follow the instructions. Whats the worst that could happen, its supposed to be haunted anyway so it definitely doesn't have to be perfect. And in the end that was true. Next time I will definitely wait to install the windows and doors until the end. It was incredibly difficult working around them, both with construction and painting. I had to touch up all the trim after I painted the house exterior anyway since the trim was already painted. Originally I had wanted to do clapboard siding but decided I was taking on too much and had to simplify. I also had primed everything on the interior, which bit me in the end because my door and window casings I ended up wanting to stain and now I wasn't able to. Hence the sloppy gray chalk paint around the interior window casings. But, again, its haunted so who cares. I definitely should have painted the interior walls before the house was done, it was so difficult painting inside...I also should have put a skim coat of spackle or compound before I painted, you can see the brushstrokes. I used satin interior latex all around which worked pretty good, definitely important to have quality paintbrushes for larger areas. I also should have waited until the end to put all the gingerbread on, was unable to paint underneath it on the exterior of the house. The base and crown moulding came out pretty good, luckily any imperfections in my miters are covered up easily on such a small scale. If I was creating a masterpiece perhaps not but it worked for what I was doing. Mitering was definitely easier than coping for me. For the floorboards I snipped popsicle sticks, glued stained and polycrylic them. For the bathroom and kitchen floors I jigsawed 1/8" inch hardboard, and bought some glossy dollhouse flooring online, used Stovers glue to glue it to the hardboard. Then could insert the whole thing into the house. I bought a package of assorted dowels from walmart and used square ones for trim to separate the kicthen from the living room and the living room from the bedroom (where the staircase opening is). I probably should have swapped where the kitchen and the living room is, but it seemed strange to have stairs in the kitchen. Looking at it now though its kind of funny having such a huge kitchen and small living room lol. I used wood glue all around and E6000 to glue the shingles. The roof was probably the biggest timesink it was very difficult cutting around the dormers and gable. But I think it came out awesome I stained it using a foam brush after the glue was dry. The yard I used foamboard, sand, gravel, moss, and glow in the dark glass for the pond. All materials bought at Home Depot and Michaels. Furniture is so expensive, its hard to justify spending so much after buying a $39 dollhouse kit lol. However after researching it seemed like the Melissa and Doug sets were the most bang for the buck. They're good enough but not great. I got the bathroom set from Amazon. I had to leave out the armoire and the bathtub, house is too small. Oh and I forgot to paint the inside of the front door. LOL Anyhow, I thought the house came out pretty good. Thanks for your help along the way. Please share your thoughts, comments, and suggestions! Happy Halloween!
  9. Well its been over a year but dollhouse is finally complete in time for Halloween! Just thought I'd share a photo to this topic. I will post more photos in a separate post. Thanks for the help.
  10. I know its been over a year but dollhouse is finally complete (mostly). Here's a pic of how the floor came out. I ended up just snipping the popsicle sticks, gluing them, staining them, and a couple coats of polycrylic. Not perfect but it came out pretty nice. I'll post more pics of the dollhouse in another post.
  11. Thank you everybody, a lot of great ideas and photos here. I may just use the square ended craft sticks from Walmart in the interest of saving time...then I'm guessing a bed of wood glue and lay them all down with some weight to keep them flat? Do we try to alternate lengths so they don't all butt up to each other at the same spot on the floor? Then I'm just planning on taping off walls (which are primed, I doubt I'm going to do much with them this year as I want this in time for mid October), and brushing on some stain. Was also planning on staining the stairs the same color and spray it with some spar.
  12. I just found those too--they seem perfect and will definitely save time. As long as you you don't need wide floorboards typical of old houses they are fine. I think the ones I bought are 1/4" wide, so equivalent to 3" wide boards. It definitely works.
  13. Oooh, a mini miter saw! I love it.
  14. Working on my first house, the Orchid...haven't gotten to the interior yet but thinking ahead I was planning on doing hardwood floors using popsicle sticks, any handy tricks to making the round edges square? Or just dremel or snip each one by one? My floor is slightly under the front door entrance right now. Directions say to ensure its level with doorway, but it seems better to have it be a little lower to allow room to install the flooring.
  15. What a great idea with the bamboo skewers for the bay window. Thank you!
