Bob Dwyer
New Member
  • Content count
    4
  • Joined
  • Last visited
Community Reputation
2 Neutral
About Bob Dwyer
  • Rank
    New Member
  • Birthday 11/30/47
Profile Information
  • Gender Male
  • Location Myrtle Beach, South Carolina, USA
  • Interests Sailing, Ludwig Wittgenstein, Charles Dickens, Bruno Snell, Francis Cornford
Previous Fields
  • Dollhouse Building Experience One
  • Dollhouse Preference The Traditional Greenleaf
  • Online Community Building Projects Yes
  • Digital Camera Yes
  • Real Name Robert
  • Country United States
  1. Beacon Hill Front Porch Roof
    The porch trim assembly was put together using Titebond II Premium. A mixture of equal amounts of water, vinegar, and acetone dissolved the glue without damaging the wood.. Just put a little bit along the joint. Let it sit for about 10 minutes, and then scrape the glue with a very thin object like one of those screwdrivers used to tighten the screws in a pair of eyeglasses, and gently pull the soffit out of the assembly.
  2. Beacon Hill Front Porch Roof
    OK. Thank you Shannon60 and Havanaholly. I had the gap because I didn't follow the directions, which say, "Tip Trim B [the soffit] up, between arms of assembly, align flush with LOWER edge of main beam section. (G). I had goofed and glued it to the upper edge. After it is glued properly it should look like this (more or less):
  3. Beacon Hill Porch Posts
    The link is no longer working.
  4. Beacon Hill Front Porch Roof
    Evy, Did you ever figure out the roof problem? I now have the same trouble. I've read the directions carefully, several times, but can't figure it out.  Is the roof to be tilted down to the trim assembly? Thanks, Robert
