Just One More Posted April 5, 2008 Share Posted April 5, 2008 What is the best glue to use with Greenleaf-type siding. I've used Quick grab for the heavier siding that is thicker and with the ridges formed in. I've used Aleen's when I didn't overlap GL siding but had to use weights. Which is best? Quote Link to comment Share on other sites More sharing options...
jeninky Posted April 5, 2008 Share Posted April 5, 2008 I would PM Linda she has worked with that siding before...I asked her about it but never asked her what glue she used... I am curious on the response you get too! Quote Link to comment Share on other sites More sharing options...
havanaholly Posted April 12, 2008 Share Posted April 12, 2008 I don't know what Linda has used, I always use the wood glue and weight it down. Quote Link to comment Share on other sites More sharing options...
chesterfieldzoo Posted April 13, 2008 Share Posted April 13, 2008 I just use Aleens or wood glue. Tape or maybe pushpins to hold it in place if you don't want to weight it down. Quote Link to comment Share on other sites More sharing options...
justmesue Posted April 20, 2008 Share Posted April 20, 2008 I used quick grip and omni stick, and loved the results. Instant gratification!! It's worth it! I'm not patient enough to wait for the wood glue on finishing toches like shingles or sidding! I've also used slow setting glue sticks on the shingles of the Adirondac cabin. They were purchased at a doll shop, and I thought I'd try it. It worked well, just don't know how long it will hold. Quote Link to comment Share on other sites More sharing options...
MaineYankee Posted April 22, 2008 Share Posted April 22, 2008 I like contact cement for a strong, permanent bond that you don't have to hold in place. With contact cement you brush it on both surfaces, let it dry 15 minutes or so and then, when you put it in place, you're done! Make sure you get it aligned the first time, though. No second chances Quote Link to comment Share on other sites More sharing options...
More Minis Dollhouses Posted April 27, 2008 Share Posted April 27, 2008 I always use Aileens Fast Grab tacky glue and its worked great. I havent had problems with having to weigh the siding down or anything like that. I use binder clips to keep it flat around doors and windows and masking tape on the corners. I like the fact that the water soluble glue warps the siding a little upwards and once its dry, its flat again but always slightly up, not flat like when you use hot glue. It just looks prettier that way. I used hot glue on my first Beacons siding and didnt like how flat the siding came out. I like to see the lines and texture. Quote Link to comment Share on other sites More sharing options...
Sharon-UK Posted April 30, 2008 Share Posted April 30, 2008 I used QuickGrab for the single board type siding, and when I ran out of that, I used Bostik or UHU which are similar solvent based adhesives here in the UK. I liked them for their quick set but still giving some wiggle time. Also, if you change your mind or make a mistake, you can pry them off again without hurting the house (although the board may not necessarily survive). It can be pretty hard to clamp boards due to the awkward shape of the Willowcrest, and it isn't practical to turn it onto its side to weight boards, so I liked the quick no clamp hold of the solvent glues. Make sure you have good ventilation though. Quote Link to comment Share on other sites More sharing options...
bookmarm Posted May 10, 2008 Share Posted May 10, 2008 I've used Quick Grab, Alleene's quick dry thick glue, and extra thick Elmers wood glue. Then I use lots of clamps and clothespins. Quote Link to comment Share on other sites More sharing options...
chattycathy66 Posted May 10, 2008 Share Posted May 10, 2008 I used Quik Grip and loved it! I also "taped" it down with that blue painters tape til dry, and it turned out pretty well....It's just that crazy, crazy little tower wall I'm working on now!! Quote Link to comment Share on other sites More sharing options...
Just One More Posted May 11, 2008 Author Share Posted May 11, 2008 I'll have to experiment with the quick grab and the thicker glues on a small house like a cottage. I like the way the siding came out unlapped. I did that on two Jeffersons and it gives the house texture rather than just the bare plywood but overlapping would look better. The push pins are a good idea. I have bags of GL siding because I usually don't use it but I really have to learn to put it on. I may get another Arthur and try it. I've been wanting to do another Arthur with an addition. I like the LE Arthur but will just get the original version. I like having stairs. Quote Link to comment Share on other sites More sharing options...
havanaholly Posted May 11, 2008 Share Posted May 11, 2008 Pat, I use the GL siding strips vertically, without lap, for beadboard (especially the bathroom in the Coventry Cottage), and for that I used wood glue and then clamped a piece of scrapwood on top to hold it all in place until it dried, beautiful & FLAT. I'm with you on the LE Arthur; when I build mine, it has a treatment in mind and siding ain't it! Quote Link to comment Share on other sites More sharing options...
