Started Westville
Ken
I use Probond to assemble kit houses, and I wait until after the rest of the build and decorating to install the windows and doors. I use clear drying tacky glue to install the acetate window inserts. I never use hot glue.
Yes you are right it can be addictive lol.. Assembling dry to see where the parts go, and how much fitting will be needed. Not too bad of what I can see right now. Now disassemble and start reassembling and dry fitting to the final fit. Then disassemble and sand parts Then start assembling by the instructions. I have noticed really tight tabs that will have to be loosened up a bit to allow for the glue, Also some gaps that sre up to 3/16 and easily removed by resizing the tabs or slots so they will fit without forcing them, I know in furniture building if you have to force a joint it's a bad joint.
HOT-Dang-This is
http://i1164.photobu...6h/8539a2dd.jpg
http://i1164.photobu...6h/12a426af.jpg
Edited by Ken
Coming along nicely. I think my Westville interior wants to be in the Craftsman style, but am thinking I may have to leave out kitchen for dining room with built-in cupboards.
If I ever build one for myself, Craftsman is the way to go, and I think I'd steal a page from Judith's book and bash an add-on diningroom (or porch) off of the kitchen, and make louvers for the attic windows to make it a summer sleeping area.
You both have some good ideas - I have been lookig at it and thinking about (Maybe) On the right side instead of bay windows French doors.. That could open onto a small deck or something.
Not a lot to report - Have been working on final fit all week , I only get a little time in the evenings and week-ends to work on this. The fit now is just where I want it everything is square and good fitv at the joints. Now disassemble and fine sand everything and start assembly.
http://i1164.photobucket.com/albums/q580/wf6h/dccb4e9a.jpg
http://i1164.photobucket.com/albums/q580/wf6h/893caf4f.jpg
On this picture I will be cutting the rooh up a bit - Just doesn't seem right you can't see the windows. Either way I think I will like it better.
http://i1164.photobucket.com/albums/q580/wf6h/a30cfb75.jpg
Looking good! That roofline blocking the windows always seemed strange to me, too. (I left the windows out on mine.)
About your French door / deck idea, I haven't seen it but a lady who works at my local miniature shop told me she did that with a Westville.
More progress - Building a whole new staircase - This is out of poplar which will be sanded sealed and painted - Then will mill Oak stairs treads only - I feel it will give more room behind the stairs for other items or I have been toying with the idea of a eggcrate between the rooms that idea is still up in the air.
http://i1164.photobucket.com/albums/q580/wf6h/98d4983e.jpg
The second I milled new posts for the front porch have a few ideas up there also.
http://i1164.photobucket.com/albums/q580/wf6h/2d3d4c97.jpg
Yea I saw that Holly and looked really neat ..I almost went that route , Then finally decided to eliminate that wall .. More room and being able to see through the stairs I like.. Now doing the handrails .. Hot-Dang this is fun..
Edited by Ken
That's for sure! My customer wanted me to build the kit "as is", but she was a friend, so I snuck in some little "extras" for her. If I ever build one for myself I think I'll go Judith's route and bash a couple of extra rooms; and since it's a Craftsman bungalow, I'll do some twiddling with the stairs, too.
I just can't help myself - My biggest joy is detail work and fiddling with things - Going back I can't ever remember building anything by the plans, I'm not 100% sure exactly where this will go , I do know that this being my first I really have to be careful when I glue up something so am following the instructiond carefully. I mentioned an Eggcrate I like that as my grandmother had one between the living room and the kitchen can always remember all the nick nacks on it..
Edited by Ken
AWWWWW The week-end has arrived - Need to do some mill work so I can continue on. So I did
Picked up some poplar
http://i1164.photobu...6h/8fa33b68.jpg
Then milled some to 1/8" X 1/4" for window trim
http://i1164.photobu...6h/a01dca99.jpg
And somemore to 1/2" x 1/8" fot the window sills.
http://i1164.photobucket.com/albums/q580/wf6h/b4b7c8e3.jpg
Now to press on..
Edited by Ken
Ooo, pretty!
Thanks Holly - I have always like working with Poplar wood - works very well takes stain and paint very well.. I will try to eliminate as much of the ply stuff I can - With in reason.
