Garfield just arrived!
13 posts in this topic
Hi from CT! The Garfield is my first dollhouse build. Very excited! Has anyone primed the sheets before punching out the pieces or would it be best to prime piece by piece as I go along so it's not even more difficult getting the pieces out?
Welcome to Greenleaf.
Definitely don't prime while still in the wood sheets. You'll have a nightmare trying to get them out afterwards without breakage and splintering. It's a lot of work to sand and prime but well worth it.
Also don't follow the instructions that say to use hot glue. It won't hold up over the long haul. Use a good wood glue or white tacky glue instead. Painters tape is your friend for "clamping' things together while they dry as well as for dry fitting (test fitting) the shell together before gluing.
1 person likes this
Welcome to the little family.
...Has anyone primed the sheets before punching out the pieces...
I did that once, with a Buttercup. NEVER do this. I will never do it again! The sealer/ primer will fill the stamp cuts and the wood will swell and you will go through many utility knife blades to get the pieces out, and that's just if you only did one side. I think you'd have to use a bandsaw to remove the pieces if you did both sides first. Totally never do this with a kit as huge as the Garfield! You will want to do lots and lots of dry fitting, so invest in several rolls of painter's tape.
One of the moderators please remove the duplicate.
I'll bet you dreamed about your new Garfield last night and all the fun (and hard work) you'll have with it.
The planning is half the fun. I keep those little inexpensive composition notebooks (graph paper style are my favorite) or a sketch book handy to jot ideas and little sketches in as I begin work on a new build.
I have a Garfield but it's still not finished - life and other kits interrupted it's completion. Someday ...
Welcome to the forum, Bonnie.
I tend to sand the pieces of the shells after I remove them - it makes for a better fit in the end... glad you joined us!
Hi Bonnie,  I just started the Garfield House as well.  It is also my first build.  I hope you are enjoying it like I am.  It is my new addiction.  Good luck
Hi, from another Connecticut resident, and welcome to the forum. It is nice to have you here :)
Selkie is right.  Don't prime before you punch out!  Wood glue prefers to stick to wood - not primer.  And it is hard enough to punch out some pieces without extra stuff holding them in place.
If you intend to paint, I wouldn't worry about using primer.  However, I would take your spackle (you gotta have that!) and work on a thin coat applying it against the grain.  This will fill all of the open pores in the wood.  Once it is dry, give it a good sanding with 180grit paper and then paint.  Your wall will look like a professional drywaller did the work!
1 person likes this
Oh great.  I just primed both sides of sheets for my Orchid (my first build) because I saw several YouTube posts that said to do it that way, and it made perfect sense.  I hope I didn't ruin the fun of building before I even got started!  I guess I better pick up some more X-Acto blades.
You can still get them out but you'll need to be especially careful with the gingerbread trim pieces and other smaller ones as well. They can break easily anyway so do get a good utility knife with fresh blades and, if you can, do it sooner than later. Paint is still soft (not cured) for a week or so.
Look at it as your first level on the learning curve. You passed!!  :bigwink:
  • Similar Content
    • My Garfield Arrived
      By Rose
      Well my house finally arrived. I have mixed feelings. lol The Garfield is a beautiful house but I do not like the wood. I built my first Greenleaf house 15 years ago I think. Since then I've only built the MDF houses. I have to change my whole way of thinking through this. I will definitely follow the directions. They are hard to understand though. I found Ginas(More Minis) blog and it is sooooo helpful. Thank you Gina! With my mdf houses I always prime the inside walls with paint so the bare wood won't suck up my wallpaper paste. I will do the same with these. My question is about this wood warping. Should I prime before I put the walls up or will it be ok to put the walls up and then prime them. Will they warp while standing. MDF doesn't warp so I never had to worry about that.
    • Beacon Hill Christmas Gift
      By JennyBuilds
      Hi everyone. Thank you for taking the time to read and comment! I have read the instructions thoroughly, as well as the warm up sheet, but I am having issues differentiating which pieces are which!! They are unlabeled. Am I supposed to remove everything from the box and label? This was specifically prohibited in the instructions I read as it said to remove and use IN ORDER, but I am unclear how in step A I am supposed to locate foundation back (1) and bottom support (27)!! SEND HELP!!
    • Fairfield, McKinley, Garfield - Between Santa Fe and Albuquerque
      By Talina
      I have two partial kits-Fairfield and McKinley-free. I also have a Garfield that has been started. Whoever started it has done a beautiful job so far.all the punched out parts are bagged and labeled. Not really shippable,but willing to meet people part way (located between Santa Fe and Albuquerque). Want a totally reasonable amount. Mostly want it to move on. Contact me for pictures,as I don't seem to upload pics.
    • New to Miniatures
      By InfamousZim
      Hello everyone! As the title states I am new to this, but I have just purchased a partially finished Victoria’s Farmhouse. It’s basically a shell.
      However, I have lots of questions!
      •What tools should I get and invest in? Are there ones you wish you had when you were starting or one you can’t live with out?
      •The dollhouse is missing a piece! What should I do, is there a way to get a replacement?
      •The walls were not glued flush. There are gaps in a couple of places and the piece that is missing wouldn’t set flush if I had it because the roof would but up against it. There is one that is not glued on one side. How can I fix these?
      •The entire outside is pairing a deep blue with bright trim. What is the best way to paint over it. I want white trim with a lighter exterior color.
      •All the dowels and railing pieces are painted as well. Would it be best to sand and repaint or buy new dowels. There are over 150 pieces that are painted, mostly dowels.
      Any help or resources would be appreciated!
      I am trying to figure out how to post pictures but they are all to big. Any help there would be great as well!
      Thanks,
    • Hello from Idaho!
      By MiniGiggles
      Just saying hello and introducing myself. I'm pretty new to miniatures. I've always loved little things but it wasn't until my sister got a huge 1:12 scale dollhouse from a member of her community that I realized miniatures was a hobby. At that point I got myself The Fairfield and I haven't looked back! I'm still working on my Fairfield and a few days ago I got The Garfield from a lady in my own town for an awesome price. I've wanted The Garfield ever since I've laid eyes on it so I snatched it when I had the chance, even though I'm still working on my Fairfield. Unfortunately, whoever put together the Garfield, did a poor job and it wasn't very well cared for. Everything I've found so far has been put together with hot glue, it's got tabs out of slots, pieces coming off,'s got some damage to multiple windows, shingles and a few doors. It's also missing a few pieces here and there. I'm excited to clean and fix it up but worried about some changes I want to make. I want to alter some of the layout during repairs but not sure how much I can do without breaking the house further.
