Tell Me About Clamps, Please
17 posts in this topic
I know I will need clamps, but I'm trying to figure out how many of each kind/size I should have on hand as I get started with my Orchid.  At Hobby Lobby I was unable to find any of the plastic bar clamps like those blue ones for dollhouse building I see in photos, so I presume I will need to get them online.  I want to make sure I purchase enough, and truly appreciate your input.
http://www.ebay.com/itm/Plastic-Clamp-small-tools-model-miniatures-hobby-2pcs-12333-/161729392960?hash=item25a7d2b140
http://www.ebay.com/itm/Plastic-Clamp-7-1-2-tools-model-miniatures-2pcs-/160503334789?hash=item255ebe8785
What other sorts of clamps would you recommend having in my toolkit as I begin?
Thanks!
faye
Since I do a lot of rehab work on larger houses, I went to my local hardware store and purchased a few larger bar clamps, and a couple of smaller C clamps.
3 people like this
All you really need is blue painters tape for a Greenleaf product. The blue plastic clamps are useless IMO.
Bar clamps like the ones in Jackie's photo are much nicer than the plastic ones. A couple of plastic ones are nice for right angles on furniture, but they don't clamp as well as bar clamps for most things.
The cheapest place I have found bar clamps, is the dreaded Walmart. I got some decent ones for less than $2 for the small ones, whereas the ones I got at Home Depot were around $7 each for the same size.
Spring type clothes pins are great as well, and some smaller clamps that work the same way as the clothespins, but have jaws that open wider are nice to have as well.
1 person likes this
Ooh, I love clamps! I have some of the blue ones, they do okay for the thinner wood. I have some like Jackie has too, in different sizes. I probably use those bar clamps the most. I just got mine at home depot or somewhere local. I also use a lot of the pinch-type clamps in different sizes. And binder clips... Tape works great as well for wrapping around large areas.
You cannot have too many clamps.  I get mine at Harbor Freight.  I have no use for the weensy blue plastic clamps.  I have a magnetic gluing jig I use for furniture making:
and the clamps I use the most are the plastic ones I buy by the tube from Harbor Freight:
I use the Bar clamp or as I call them my gun clamps....and the small clamps in Holly's photo....
but I agree with Sable....if you have a good painters tape you are good to go!!:bear:
I have the magnetic gluing jig too which I like using - although I put baking paper on the bottom to stop stickage.  The only thing I don't like about it is that the sides aren't completely square and I have made the mistake before of butting things up against them.  Otherwise I have a couple of little clamps - still need a couple of small bar clamps.  I'm in New Zealand and get a lot of my tools direct from Micro Mark who specialise in tools for minis!   www.micromark.com
Those blue clamps are rather useless. The only thing I find myself using them for, is taking them apart and using them as small right angles.
This is what I use:
Different sizes of binder clips. Cheap and useful for a million things but definitely helps out when putting windows and furniture kits together. Enough pressure to hold the piece together but not enough to dent the wood.
561339_sk_lg?$OD-Large$
Jorgensen 4½" Micro Clamp (what I use in place of the blue clamps) About $5 a piece
You probably won't need these but I have a lot of 2" and 3" pony clamps that I use at times when something really needs to be tight or encouraged to stay in place. They are a couple bucks a piece.
Blue painter's tape. You need this for renovation painting but take enough of it and you can hold things together pretty tight when gluing.
Lastly, I use these to weigh things down or into place. Warped floor boards, for example. I also use them to create 90 degree angles when gluing things together. They are great at forcing thin warped pieces to dry flat. 1-2-3 Machinist Blocks, about $15 for 2. They are 1" x 2" x 3", hence the name. Each weighs 1lb 11oz
1 person likes this
I use my old nursing textbooks for flat weights.
I also ordered extra magnets, and I have had a couple of projects where I used all of them, plus clamps.
I just finished the Orchid. I used blue painters tape for almost all of it. Buy two rolls. I also used binder clips and clothespins. You really don't need anything else, so save your money. I found using Legos to get a good square edge when gluing together small bits (porch stairs, stair landing, etc.) worked really well.
  • Similar Content
    • Beacon Hill Christmas Gift
      By JennyBuilds
      Hi everyone. Thank you for taking the time to read and comment! I have read the instructions thoroughly, as well as the warm up sheet, but I am having issues differentiating which pieces are which!! They are unlabeled. Am I supposed to remove everything from the box and label? This was specifically prohibited in the instructions I read as it said to remove and use IN ORDER, but I am unclear how in step A I am supposed to locate foundation back (1) and bottom support (27)!! SEND HELP!!
    • New to Miniatures
      By InfamousZim
      Hello everyone! As the title states I am new to this, but I have just purchased a partially finished Victoria’s Farmhouse. It’s basically a shell.
      However, I have lots of questions!
      •What tools should I get and invest in? Are there ones you wish you had when you were starting or one you can’t live with out?
      •The dollhouse is missing a piece! What should I do, is there a way to get a replacement?
      •The walls were not glued flush. There are gaps in a couple of places and the piece that is missing wouldn’t set flush if I had it because the roof would but up against it. There is one that is not glued on one side. How can I fix these?
      •The entire outside is pairing a deep blue with bright trim. What is the best way to paint over it. I want white trim with a lighter exterior color.
      •All the dowels and railing pieces are painted as well. Would it be best to sand and repaint or buy new dowels. There are over 150 pieces that are painted, mostly dowels.
      Any help or resources would be appreciated!
      I am trying to figure out how to post pictures but they are all to big. Any help there would be great as well!
      Thanks,
    • Beginner - 1st dollhouse - Tennyson
      By jkortidis
      Greetings, I bought the Tennyson kit in a garage sale. I have 2 young great granddaughters that I am planning to make very happy with this project. Also, my husband has been open to helping me learn how to build with wood. So this will be my first project and I'm excited!
    • Victoria's Farmhouse for beginner?
      By Beginner Amy
      Hi
      My name is Amy, I am new here, and I have never built a dollhouse from the ground up.  My daughter, who is 9, wanted to build the VF with me.  Would this house be too difficult for a beginner?
      Thanks!
      Amy
    • Rekindled love, first build, help & advice
      By MiniLindsay
      Hi there Greenfield community! I've been lurking for several weeks on the forum and finally worked up the guts to post.
      I gave away my childhood dollhouse and extensive collection in my teenage years - I thought I grew out of the hobby. Little did I know that I would become massively obsessed with creating a new dollhouse in my mid-twenties! I believe it is due to this middle point in my life, where I have a growing career and finally have money, but don't have enough to buy a house, and I don't have anyone to buy one with, yet. Solution: make my own miniature version. For that reason, I am drawn to more modern, glam styling reminiscent of West Elm and all of the bright white, grey and gold styling of Pinterest. What can I say.
      For my first build ever, I chose the modest Greenfield Arthur. I thought four rooms wouldn't overwhelm me too much, and it was an inexpensive kit that I could cut my teeth on.
      I'd like to get some of the community's feedback on what techniques I've used so far, and also ask for some help.
      1) I popped out of die-cuts only the pieces that each step called for to prep. I sanded lightly those pieces, then primed (latex primer from Home Depot). Sanded again, sometimes primed again, and sanded again. For the little pieces of trim and the stairs and such, I actually painted primer over the entire sheet while the pieces were still die-cut in the sheet. Good/bad? Yay/Nay? I did this to most of the main pieces (base, second floor, sides, partitions and roofing) before I even pieced them together for a dry build.
      2) THEN I dry fitted the main pieces together. I found that most of the slots didn't fit, so I ended up using an exacto knife to ensure they fit flush with their counterpart. I used masking tape to hold it together.
      3) At this point, I knew that It was going to be more difficult to wallpaper and install flooring while the house was constructed; so I opted for wallpapering and flooring before the house was glued together, while the pieces were flat. This was an option given in the handy Warm-Up Instructions in the kit. So far in all of my research, I haven't seen much of that done, is there a huge disadvantage to doing these items before it's glued together?? See my photos for my handmade hardwood floors and one side of wallpaper so far. What I did was made sure the pieces were nice and primed and sanded so that they were smooth, then sprayed them with spray adhesive, then laid the piece onto my paper, right away. After that, I took my exacto knife and cut around the piece and through the window holes.
      4) ROOKIE MISTAKE NUMBER ONE: I wallpapered the wrong side of the house on accident. I'll put that in the books.
      5) ROOKIE MISTAKE NUMBER TWO: I wallpapered the right side of the house, but I put the piece down on the wrong side of the paper. I had to quickly rip it off and turn it around. Now there is a little sticky darkness on my paper. Sad day. It's easy enough to cover with a picture frame or painting, but still. I'm sort of a perfectionist.
      6) So, right now the status of my house is that most of the interior walls are intermittently taped together in the dry fit, but I'm stuck on what color to paint the bedroom.
      Kitchen - Bottom right corner room - marble flooring and subway white tile wall accent on right side, still unsure of other walls' color. Probably white. Living Room - Bottom left corner room - reclaimed wood style hardwood and white brick accent wall (should I do actual textured brick, or wallpaper?? Any good suggestions for where to get this?) I want to put a pink fireplace on this wall. Chic! Bathroom - upper right corner room - grey longitudinal stripes and pink walls, fabulous gold hexagonal tiling for flooring (yay for cute scrapbook paper!) Bedroom - upper left corner room - grey latitudinal stripes with whitewashed boarding (created with large popsicle sticks) that goes up to the window height. Still debating on other walls in this room and also the flooring. I have nothing for the bedroom really figured out at all.
