Luanne Posted May 25, 2016 Share Posted May 25, 2016 Hi guys, I am so bummed out. For some reasons, half of my tape wired lights are operating at 20% capacity. These are plug in to an outlet, not battery operated, and they are old school lights, not LED's. These were installed when I built the house in 2007 or so. Some of them flicker slightly at times. They were not designed to flicker. I am most concerned about the brightness issue. Have you heard this before? Will they be back to normal brightness with use? Do they need to be used daily for a certain required timeframe to be maintained? What's happening? How did you fix this if you had this issue? Thanks for any diagnosis and suggestions. Here they are at 100% brightness capacity. Now half of the house is really dark. https://www.flickr.com/photos/54971771@N04/8010821119/in/album-72157627103452609/ Quote Link to comment Share on other sites More sharing options...
MLI Designs Posted May 25, 2016 Share Posted May 25, 2016 That's such a bummer. Hope someone could help you out. I'm new to lighting and decided to go with round wire. Good luck. I'm sure someone will offer advice Quote Link to comment Share on other sites More sharing options...
Sable Posted May 25, 2016 Share Posted May 25, 2016 Are you using a transformer large enough to cover the number of bulbs? Please look at the transformer and post what the watts/amps are. Are the bulbs replaceable screw in bulbs? 2 Quote Link to comment Share on other sites More sharing options...
mesp2k Posted May 25, 2016 Share Posted May 25, 2016 I'm thinking the branch of tape wire going to the dim side of the house may have lost some contact point between a brad & section of tape wire. If it was 2007 & the tape wiring was still exposed you could test the connections & track down the problem. No clue on fix? Hmm...replace with battery lights? Quote Link to comment Share on other sites More sharing options...
Luanne Posted May 25, 2016 Author Share Posted May 25, 2016 Thanks guys, I will check the transformer power. It was my 1st house, I remember consulting with Miniatures.com by email about the transformer. Yes the bulbs are replaceable and as of this moment I am thinking battery lights are a good idea for future projects. I'll check out the connection as well. Thanks again. L Quote Link to comment Share on other sites More sharing options...
Luanne Posted May 26, 2016 Author Share Posted May 26, 2016 I replaced 3 bulbs. One is the same brightness. The other two improved. I can live with this. The transformer is labelled to power up to 16 bulbs, the house has 10. Thanks for thinking this through with me! I am grateful as always. L. Quote Link to comment Share on other sites More sharing options...
aggiemae Posted May 26, 2016 Share Posted May 26, 2016 Are all the bulbs the same voltage (amperage?) i don't think your supposed to mix them. 1 Quote Link to comment Share on other sites More sharing options...
Luanne Posted May 26, 2016 Author Share Posted May 26, 2016 Yikes. I hope it's ok. Quote Link to comment Share on other sites More sharing options...
aggiemae Posted May 27, 2016 Share Posted May 27, 2016 9 hours ago, Luanne said: Yikes. I hope it's ok. It isn't dangerous, it just makes the bulbs burn out faster. One of the problems with buying used/ unlabeled fixtures. Quote Link to comment Share on other sites More sharing options...
