29 posts in this topic
Hi,
My name is Erica and I recently ordered the Greenleaf Willow kit (due to arrive tomorrow), as well as purchased a partially complete Greenleaf Garfield (which is HUGE!!!!).  The Garfield has quite a bit of damage and work that needs to be done so it is more of a restoration/build.  Super excited to join this group and build my dollhouses.  I'm 32 years old and have never had one for myself, and I have two boys so I figured I better make one for me since I probably won't have a daughter.  I live in San Diego, CA.  I have two boys age 10 and 7... and a small boston terrier named Roxy.
Welcome to the little family Erica.  If your Garfield was built with hot glue you can take it apart with your blow dryer or a heat gun.  I think the big houses are fun to rehab, because no matter what you do to them it's an improvement.
1 person likes this
It looks like wood glue.  The only things I am considering pulling apart are the doors and windows (the window inserts got a lot of spray paint on them) and adding my own windows to them... as well as working doors.  All of the railing outside needs to be replaced.
I also easily removed a fireplace inside of the house (which was oddly placed against stairs and was bugging me haha)... that removed very easily.
I had no idea how big this house would really be.  It definitely will not fit in any of my bedrooms.  It will stay in the living room.
Hey Erica, welcome to the forum! :gathering:
That Garfield looks like it has good bones.  What are your plans for the Willow?
1 person likes this
Hello!  It does feel solid so that's good!  For the willow, I'm going to paint the exterior siding white and the shutters black, dark red door.  The shingles I would like to stain a dark grey color.  The two chimneys I would like to add a brick-like finish to them.  Also planning on adding mainly wood flooring with coffee stir sticks, tile (or fake tile) in bathrooms and kitchen.  This is how I basically want it to look on the outside.
Hi and welcome!
The willow DH looks like a good  solid beginner project. The Garfield should be fun rehab.  Looks like it's not all that bad shape. Can't wait to see more pics.
1 person likes this
cool-613.gif.fabf9fceab2f8926ef74eb675c5
note: egg cartons = bricks
I highly suggest you decorate it with the colors of the living room. It should blend in with the rest of your decor.
1 person likes this
Coffee stir sticks do not butt up well against each other. They can also be very wavy. It cost more money but I have had much more success with basswood strips cut into random widths.
It all depends what you want the end product to look like.
1 person likes this
6 hours ago, rbytsdy said:
Welcome, Erica. Looking forward to seeing your Willow build. I did a "stone" (egg-carton) Willow; it's a nice big open palette.
WOW!  that is amazing!  I'm going to have to look up this egg carton technique!
I ordered a large lot of them (1000), based off of tutorials I saw.  I also picked up a bag of popsicle sticks from the 99 cent store today.  I'll play around with the options.  I don't mind sanding the edges and or filling in minor gaps.
I figured out how to get it into my guest bedroom, I removed the door from the frame!  It wasn't easy as I was all alone, but I got this huge dollhouse in the spot I will keep it in.  The room is semi shabby chic.  I am considering many color schemes at the moment.  Once I tackle the siding, I'll have a better idea of what I want it to look like.
Suggestion: if you are going to stain or paint the floor, do it to the underflooring, so if there are any tiny gaps between the boards they won't be as noticeable as raw wood.
Also, if you are going to stain, do it before gluing the sticks down. Stain won't color glue. Even small touches of glue will create eye-catching oopsies.
If there are fairly large gaps, mix sawdust and white or wood glue to use as a filler. Add a drop of stain to match the finished stained color while the mixture is wet. It won't take stain after it has dried.
1 person likes this
Erica, do listen to Kathie about staining your base floor whatever color you're staining your floor "boards".   I use the iron-on wood veneer strips, cut into lengths & split into widths:
For "bricks" I use sandpaper:
1 person likes this
If I stain the base floor, can I still use wood glue to glue the sticks to it or is there a better option?
Also, can I call/contact Greenleaf about replacement parts?  Most of the windows on the Garfield have spray paint on them, and the wraparound porch is too broken to repair.
Give the stain a few days in a warm, dry place to thoroughly dry & you ought to be good to go.  I prestain furniture pieces before I assemble them.
As Holly said, let it dry thoroughly and the wood glue should work fine. Keep in mind that you don't have to smear the entire surface if the boards with glue. Dots of glue will hold it and reduce the possibility of warping.
1 person likes this
Welcome, you spund much more prepared than I was.
You may have boys, but I just made my grandson a castle for his lego knights, so you never know.
1 person likes this
Sounds good.  Any tips on refinishing the stairs in a house that is already put together?  Looks like they stained the stairs but did not put any sealant on them so it is looking a bit faded and "ugly".  Not sure if I want to paint the entire staircase, just the banisters, leaving the steps looking wooden.  In the Garfield, the upper stairs are more difficult to get into.  I'm super scared of pulling them out to fix!
thank you Jo!  It is really funny because I didn't think my boys would be into the dollhouse.  My 10 year old is interested in the build process and how it looks but my 7 year old (almost 8) fell in love with the house!  He plays around with a few of the furniture pieces that came with it, and he has chosen "his" room in the house and how he wants to decorate it.  It makes me so happy!!  I can't wait to get it all completed so he can play with me.  I also offered to build him a super hero house once i get the two i'm working on completed.
2 people like this
  • Similar Content
    • My Garfield Arrived
      By Rose
      Well my house finally arrived. I have mixed feelings. lol The Garfield is a beautiful house but I do not like the wood. I built my first Greenleaf house 15 years ago I think. Since then I've only built the MDF houses. I have to change my whole way of thinking through this. I will definitely follow the directions. They are hard to understand though. I found Ginas(More Minis) blog and it is sooooo helpful. Thank you Gina! With my mdf houses I always prime the inside walls with paint so the bare wood won't suck up my wallpaper paste. I will do the same with these. My question is about this wood warping. Should I prime before I put the walls up or will it be ok to put the walls up and then prime them. Will they warp while standing. MDF doesn't warp so I never had to worry about that.
    • Do You Believe in Siding After a Build?
      By third_hand
      Hi everyone! I've had a long quiet period on here, but I've been steadily working away and going to shows/shops (I was at Good Sam in San Jose and was fortunate to visit Dollhouses, Trains, and More in Novato, CA for their closing sale). I will, finally, post a batch of haul and progress photos in the first week of November, when I get settled back into my home in Eugene. I really am terrible with a camera and it bugs everyone I know! In the meantime, I have a question:
      Has anyone ever tried adding siding after their build's exterior was complete? Still being a novice, when I finished my first build (the Orchid; the interior is still a work-in-progress) I stepped back and thought 'I think I should have done siding.' Especially with the shingles on, the level of detail on the exterior just varies too much; it's been irritating me for a couple of months now. I'm a bit of a stickler it seems (though I didn't know it at the time)! My window/door casings, dormers, gingerbread, and my custom porch/railings are all already in place. I realize it may be very difficult, but the question is: is it even possible? If so, do you have any tips on how to do this?
      Any and all possible mini wisdom is welcome!
      P.S. I have the opportunity to snag a very affordable Laurel kit secondhand so I'm trying to decide where I should just start the next building with siding and call it 'lesson learned' or go back and add to the Orchid (and stash the Laurel until after the New Year, space is a very important consideration here). P.S. P.S.: I'm not a Cher fan, but I took a page out of Elizabeth's book (Studio E miniatures) since I'm always charmed by her ability to make musical jokes in her posts/titles!
    • Window Parts
      By PapaJKK
      All the window parts. After sanding, filling, sanding, and more sanding, painting, sanding, painting and sealing, the windows are ready for assembly. I chose to glue the top frame in and only the bottom frame opens. This helped make a rigid window frame that can be handled without falling apart. Notice the gluing jig I made for assembly.
    • Assembled windows.
      By PapaJKK
      15 windows, 11 pieces per window, 161 total pieces. Nice to have that bit finished.
    • Greenleaf Products, plus some questions
      By Kells
      It finally occurred to me that I'm on a Greenleaf forum and I have never shared that Greenleaf has one of my favorite and most used products, but I'll get to that last. First a couple of questions.
      Is anyone familiar with Greenleaf's vinyl tile flooring? Is it glossy, and if so, can it be dulled? I want a paved stone look throughout the entire first floor of my Creole plantation house. This product:
      https://shop.greenleafdollhouses.com/miniature-scale-vinyl-floor-tiles-grey/
      While I can do the paperclay method, I'm worried that is going to add a great deal of weight to an already very heavy house. It's Lawbre's Rosedawn and it weighs a lot even in its unfinished state.
      Added weight brings up my other question. Can anyone recommend a good brick sheet? Something textured, embossed, with the appearance of real brick? I've in the past purchased a few printed sheets of brick from England just to see what they were like and, well, I'd use them on a child's dollhouse maybe but not something on which I'm going for realism. They look good but even when not up close they are very obviously just printed paper.
      I've etched brick into joint compound (a lot of work but looks great!). I've done brick and stone out of egg cartons (also looks great!). The joint compound will make this house far too heavy, and there is no way in heck I am cutting thousands of individual bricks out of egg cartons! I am seriously hoping there's some product out there that would work.
      Okay, so there are my questions, now allow me to sing Greenleaf's praises for one of their products that is one of my favorites and most used. Their siding:
      https://shop.greenleafdollhouses.com/miniature-clapboard-siding/
      OMG have I bought bags and bags of this stuff over the years. It's admittedly a bit rough and I probably wouldn't use it to side a gleaming mansion, but it has so many other uses! Here are some that I've used it for.
      It's perfect for siding a farmhouse or other "rustic" building. A simple wash gives it a fantastic aged appearance without a ton of work futzing around with multi-layers of painting and sanding and aging techniques. Some awful blurry old pics below of my farmhouse when it was in progress. I don't think they show just how fantastic that siding looked IRL.
      Another pic below is a pic of a bedroom in (I think) Salem, MA. See that ceiling and that planked wall behind the bed? I used Greenleaf siding to recreate that and I was totally thrilled with the result. I also used Greenleaf's shingles on that same Colonial. The front was clapboard but I shingled the sides. I needed smaller shingles because historically those were pretty narrow. I simply snapped 'em in half, no scoring required.
      The first floor of my Creole is going to be pretty "raw", with exposed brick exterior walls, but the interior walls of the first floor will be exposed planks behind stud framing. I'll be using even more Greenleaf siding for that. It's 3/4" wide so I'm going to score it at 1/2". The half-inch planks will be for the wall framing, the remaining 1/4" will be the equivalent of 3" lathing for the attic ceilings. And, of course, loads of it to plank almost all of the ceilings!
      So there are a few of my handy-dandy uses. And at $5.00 for 360 square inches, I challenge anyone to find a better deal! If you could even find something that works half as well. Do you have other-than-intended uses for the siding or other products?
      Edit: And oh yeah, it worked fabulously well for horizontal planked wainscoting in that Colonial house. I was going for a very early Colonial look so I didn't want any fine mouldings. That siding did the trick!
