Painting
15 posts in this topic
When painting the outside can someone tell me how they hide the notches
If you're not going to use siding or plaster the walls with spackle (or joint compound, or wall mud), you can at least use spackle to fill the slot spaces after you have sanded the tabs flat, and when the filler is dry, sand that smooth as well; then you're ready to prime and paint.
2 people like this
To hide horizontal notches (floor/ceiling) I've seen a piece of stripwood run across the wall. When painted, it blends into the wall and looks like an architectural component.
Thank you for your reply, I was talking about the outside of the house
1 person likes this
Holly and I are both talking about the outside of the house. The methods we describe are for covering the little areas where the tabs from the ceiling/floor pieces fit into the slots in the walls. Where walls are notched at corners, Holly's Spackle/joint compound/wallboard mud system also works. Some people also put corner molding on the corners to cover those irregularities.
If this isn't what you mean, can you please explain or show a photo?
Covering with spackle as a plaster or stucco treatment:
with corner molding:
and with siding:
You are great teachers.  Thanks for being so thorough, it helped me too,
1 person likes this
4 hours ago, mesp2k said:
583b057f9d0d6_finishtabs.jpg.f531027d27e
Thank you for your help
1 person likes this
It is just too cool how you can do this mockup. The wood even looks like Greenleaf's veneer. Thanks for taking the time to create this.
1 person likes this
This is awesome. If you make more tutorial pictures like this you should link them all together somewhere so we can find them!
1 person likes this
Since I used clapboard siding it was easy to cover any notches but all of the suggestions above are excellent.
1 person likes this
I really like the elmers wood filler from Home Depot.
Some people have great success using wood filler, and others, like me, don't.  Find out what works best for you and use that.
