Sable Posted January 18, 2017 Share Posted January 18, 2017 For our club's "It Takes A Village" show project, I need to make streets and sidewalks. The sidewalks are in process. I am pouring and smoothing premixed sanded grout onto a form. Each form is 3'x18" and is long enough to be placed in front of one house. I have to make 25 of them. Eeeeek! The road is stil questionable. I used flat black paint and sprayed over long styrofoam panels. Not loving it. I spent most of the afternoon looking for cheap yoga mats for the road but the ones I found to be perfect are really expensive. Also, does anyone have a link to premade road signs? Any ideas on this will be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
wormwoodz Posted January 18, 2017 Share Posted January 18, 2017 I dunno if it will fit the look you are going for, but have you thought about maybe trying black sandpapper? I like those for street dioramas, they're cheap and look like asphalt but I haven't tried them in larger scales. About the road signs, what kind are you looking for?For 1:12 scale? Quote Link to comment Share on other sites More sharing options...
Anna Posted January 18, 2017 Share Posted January 18, 2017 As Ashley Said, depending on the look you are after, what about a piece of grey felet and then roll on asphalt grey paint on top to cerat the texture and a slight "stiffness" to the clot? Quote Link to comment Share on other sites More sharing options...
Sable Posted January 18, 2017 Author Share Posted January 18, 2017 It is 1:12 scale. About 25 Primrose dollhouses set up in a village setting. I'm going to head to Grainger to look at the sandpaper. The widest paper that comes on 30' rolls is only 4.5" wide so I'd need about 3 rolls at $60 per roll. My budget can't handle that much. But I'll have a look and see what they have. Thanks. Quote Link to comment Share on other sites More sharing options...
Sable Posted January 18, 2017 Author Share Posted January 18, 2017 6 minutes ago, Anna said: As Ashley Said, depending on the look you are after, what about a piece of grey felet and then roll on asphalt grey paint on top to cerat the texture and a slight "stiffness" to the clot? Thanks. I'll test that out, too. Quote Link to comment Share on other sites More sharing options...
Anna Posted January 18, 2017 Share Posted January 18, 2017 Had another thought tight Now when I used the cork board, what about using cork sheet, has a lovley texture to it and takes paint well too. I have seen rolls of thin cork, even so called cork fabric.... 1 Quote Link to comment Share on other sites More sharing options...
Anna Posted January 18, 2017 Share Posted January 18, 2017 http://www.printmini.com/printables/signs/speed1b.html https://www.printmini.com/printables/signs/dontsign1b.html Think these are 1:25 svale though: http://blog.modeljunkyard.com/2011/05/28/free-tutorial-making-road-signs/ Quote Link to comment Share on other sites More sharing options...
mesp2k Posted January 18, 2017 Share Posted January 18, 2017 Pre-made are pricey. Make your own if possible. Sign posts: Skewers or dowels about 1/8" dia. - cut 8-1/8" long, painted sliver / grey color for galvanized look - drill holes into (village) base to hold posts. Street signs could be done in a wood look, black on white, or white on green, etc., they're a rectangle basically. Printed, then glued to poster board, painted grey (back & edge), then sign color (front) Anna's suggested site - http://blog.modeljunkyard.com/2011/05/28/free-tutorial-making-road-signs/ has a tutorial that uses soda can metal - glue the printed sign to it! Plus the sign printies - use you printer's Reduce/Enlarge to scale the signs. I know the STOP sign is 30" across @ 1/12 that would be 2-1/2" 1 Quote Link to comment Share on other sites More sharing options...
Sable Posted January 18, 2017 Author Share Posted January 18, 2017 Thank you everyone. I might have the club members make the signage. 2 Quote Link to comment Share on other sites More sharing options...
My Miniature Madness Posted January 18, 2017 Share Posted January 18, 2017 5 hours ago, Sable said: It is 1:12 scale. About 25 Primrose dollhouses set up in a village setting. I'm going to head to Grainger to look at the sandpaper. The widest paper that comes on 30' rolls is only 4.5" wide so I'd need about 3 rolls at $60 per roll. My budget can't handle that much. But I'll have a look and see what they have. Thanks. Sable have a look at skateboard grip tape. I remember it being pretty cheap and coming in rolls. It would be sturdier than the sandpaper. Good luck! It sounds like such a fun group project! 1 Quote Link to comment Share on other sites More sharing options...
Sable Posted February 24, 2017 Author Share Posted February 24, 2017 Just bringing this up front again because it had some great info which I need to start addressing. I purchased 30ft of Grip tape from a Surf Shop. Thanks for the idea. 1 Quote Link to comment Share on other sites More sharing options...
L Swearengin Posted February 25, 2017 Share Posted February 25, 2017 Check out your goodwill or thrift stores. I find a lot of everyday items that can be used. You might find the yoga mat there. I find lots of mini pattern materials (children clothes, men's shirts etc) I have even used an old tie for upholstery Quote Link to comment Share on other sites More sharing options...
havanaholly Posted February 25, 2017 Share Posted February 25, 2017 9 hours ago, L Swearengin said: Check out your goodwill or thrift stores. I find a lot of everyday items that can be used. You might find the yoga mat there. I find lots of mini pattern materials (children clothes, men's shirts etc) I have even used an old tie for upholstery The old wide polyester neckties have the best designs for mini upholstery! 1 Quote Link to comment Share on other sites More sharing options...
