Evy Posted February 12, 2017 Share Posted February 12, 2017 This is our first dollhouse project and all has been well up to this point. We are having a problem with the front porch roof. The posts are all done to hold up the roof but the pieces of the roof part seem to have a gap between the actual roof and the portion that holds up the posts. My husband and I have been trying to figure this one out on our own but we are stuck. Any help would be appreciated. Evy 1 Quote Link to comment Share on other sites More sharing options...
havanaholly Posted February 12, 2017 Share Posted February 12, 2017 I had that problem with the porch roof on the Orchid until I figured to use those little square bits under the porch posts. Quote Link to comment Share on other sites More sharing options...
KathieB Posted February 12, 2017 Share Posted February 12, 2017 I ran into a problem with the BH porch roof, too. I abandoned the porch for the moment and am now working on the roof. I know this isn't a solution, but sometimes it's good to take a step back and come at a problem at a later date. 1 Quote Link to comment Share on other sites More sharing options...
havanaholly Posted February 12, 2017 Share Posted February 12, 2017 It occurs to me that if the BH doesn't come with the little squares you could cut yourself some from the scrap wood... 1 Quote Link to comment Share on other sites More sharing options...
Miss Mel Mel Posted March 9, 2017 Share Posted March 9, 2017 This is my first dollhouse and I am having the same gap problem with the roof. I can try the squares but I was just wondering if there is something I am missing in the assembly? It seems like they wouldn't have designed it this way? Quote Link to comment Share on other sites More sharing options...
havanaholly Posted March 10, 2017 Share Posted March 10, 2017 Melody, when you find a few minutes please post an introduction in the Newcomers' Forum. Quote Link to comment Share on other sites More sharing options...
Bob Dwyer Posted June 10, 2019 Share Posted June 10, 2019 Evy, Did you ever figure out the roof problem? I now have the same trouble. I've read the directions carefully, several times, but can't figure it out. Is the roof to be tilted down to the trim assembly? Thanks, Robert Quote Link to comment Share on other sites More sharing options...
shannonc60 Posted June 10, 2019 Share Posted June 10, 2019 You could check out: https://moreminis.blogspot.com/ Gina has blogged her Beacon Hill build (plus others) so this might help. These are on Facebook now so you have to be on Fb to see them, but they are super helpful. 1 Quote Link to comment Share on other sites More sharing options...
havanaholly Posted June 10, 2019 Share Posted June 10, 2019 Bob, this time the link works. 1 Quote Link to comment Share on other sites More sharing options...
Bob Dwyer Posted June 11, 2019 Share Posted June 11, 2019 OK. Thank you Shannon60 and Havanaholly. I had the gap because I didn't follow the directions, which say, "Tip Trim B [the soffit] up, between arms of assembly, align flush with LOWER edge of main beam section. (G). I had goofed and glued it to the upper edge. After it is glued properly it should look like this (more or less): Quote Link to comment Share on other sites More sharing options...
havanaholly Posted June 11, 2019 Share Posted June 11, 2019 I have taken assemblies apart and reglued them properly more times than I can count. I think I missed your introduction in the Newcomers' Forum. Quote Link to comment Share on other sites More sharing options...
Bob Dwyer Posted June 13, 2019 Share Posted June 13, 2019 The porch trim assembly was put together using Titebond II Premium. A mixture of equal amounts of water, vinegar, and acetone dissolved the glue without damaging the wood.. Just put a little bit along the joint. Let it sit for about 10 minutes, and then scrape the glue with a very thin object like one of those screwdrivers used to tighten the screws in a pair of eyeglasses, and gently pull the soffit out of the assembly. 2 Quote Link to comment Share on other sites More sharing options...
