mks Posted February 18, 2017 Share Posted February 18, 2017 What is the best way to connect wires from a chandelier to the tape run in an electrified dollhouse? I thought about soldering the wire to the tape run, but I have never soldered before. I would want something that would leave a smooth surface, since all my connections are to the floor above. I am currently using these self adhesive squares that came with the kit, but these are not providing the best connection. Quote Link to comment Share on other sites More sharing options...
sparklepuppies Posted February 18, 2017 Share Posted February 18, 2017 I solder my wires directly to the tape, but I have previous soldering experience, and I had the equipment. It's not really hard though. Others use grommets or brads that punch into the tape, and then wrap the wires around. Some even follow that up with a bit of solder to ensure the best connection. Quote Link to comment Share on other sites More sharing options...
KathieB Posted February 18, 2017 Share Posted February 18, 2017 1 hour ago, mks said: ... all my connections are to the floor above. I am currently using these self adhesive squares that came with the kit, but these are not providing the best connection. You might consider sticking the tiles to a cardboard template rather than to the floor itself. It will level out an irregularity that the wire or solder might create. And if there's a problem with the wiring later, having a removable floor treatment would be helpful. Quote Link to comment Share on other sites More sharing options...
mks Posted February 19, 2017 Author Share Posted February 19, 2017 Hi, Kathie. Yes, I have installed the floors above the chandeliers that so I can access them if there is a problem. I will look into both soldering and the brads/grommets. Thanks! Quote Link to comment Share on other sites More sharing options...
KathieB Posted February 19, 2017 Share Posted February 19, 2017 When you look into soldering, look for the tiny soldering guns used for electronics. You don't need the big chisel-tipped irons used for leaded glass, pipe fitting and other larger applications. 2 Quote Link to comment Share on other sites More sharing options...
LadyGunn Posted February 20, 2017 Share Posted February 20, 2017 I've only wired one house and I took the easy way out and used these chandelier adapters. There's a video here from HBS showing how they work. 1 Quote Link to comment Share on other sites More sharing options...
mks Posted February 23, 2017 Author Share Posted February 23, 2017 On 2/19/2017, 4:29:34, KathieB said: When you look into soldering, look for the tiny soldering guns used for electronics. You don't need the big chisel-tipped irons used for leaded glass, pipe fitting and other larger applications. Ok, will do. Thanks! Also, do you know if someplace like Pat Catans or Michaels sells the brads? Quote Link to comment Share on other sites More sharing options...
Sable Posted February 23, 2017 Share Posted February 23, 2017 Brads are tiny nails. I don't recommend them. Use eyelets/grommets. You need brass ones. Michaels does not carry them. Order directly from cir-kit http://cir-kitconcepts.com/shop/index.php?main_page=product_info&cPath=12&products_id=163 Quote Link to comment Share on other sites More sharing options...
Bigkims1995 Posted April 14, 2017 Share Posted April 14, 2017 I agree with you. Quote Link to comment Share on other sites More sharing options...
KathieB Posted April 14, 2017 Share Posted April 14, 2017 On 2/20/2017, 11:08:06, LadyGunn said: I've only wired one house and I took the easy way out and used these chandelier adapters. There's a video here from HBS showing how they work. The adapter in the link is a pin adapter. I've experienced a problem with this type, as gravity tended to pull on the chandelier and it fell out. I had better luck with the Brass Plated Canopy Adapter from Cir-Kit Concepts. The chandelier cannot fall out, yet it is easy to remove it if necessary. Quote Link to comment Share on other sites More sharing options...
