Erin Stockton Posted May 14, 2017 Share Posted May 14, 2017 Hi, I am the very proud owner of an Alexandria dollhouse. However, I am missing two pieces: the AXW4 and the AXW10. If anyone could help out, it would be greatly appreciated 1 Quote Link to comment Share on other sites More sharing options...
Elsbeth Posted May 14, 2017 Share Posted May 14, 2017 This is difficult with Duracraft out of business. You could set up a subscription-search on ebay and wait for a kit to show up? Or cut your replacements if you can find a local source with the kit who is willing to share. Or make some guesses and cut your own. 1 Quote Link to comment Share on other sites More sharing options...
Mid-life madness Posted May 14, 2017 Share Posted May 14, 2017 Hi Erin. I hope you find a solution to your missing pieces. The Alexandria is an awesome house. 1 Quote Link to comment Share on other sites More sharing options...
mesp2k Posted May 14, 2017 Share Posted May 14, 2017 Are these 2 pcs 1/8" plywood? You could start with a poster board template - then trace that on the some plywood & cut it out. AXW4 looks like the front pop out on the left with 2 double windows, one above the other & 3 slots. The (2) AXW3s are the left & right sides of the pop out - so AXW4 fits on these & the floor tabs. And the position/dimensions of the dbl windows should match the other dbl windows. AXW10 is the beginning of the tower (left) wall - the 2nd floor has the fancy railing cutout, but its a little simpler & narrower than the other sides (AWX11) of the tower. The dbl line (left edge) on AXW10 & both edges AXW11s is probably beveled at 22.5 degrees to form the octagonal tower. If you're really stuck - I could cut them out for you, but I would need the exact measurements & I think I only have 1/8" plywood. And I would probably need a tracing of a AXW11 for reference. The drawings from the instructions are never to scale, so you can't rely on them. 1 Quote Link to comment Share on other sites More sharing options...
Qubanqtee Posted May 14, 2017 Share Posted May 14, 2017 theres currently an Alexandria that's partially built on Ebay ...don't know where you are but maybe you're lucky enough to be close by and take a peek at the parts you need. 1 Quote Link to comment Share on other sites More sharing options...
Erin Stockton Posted May 15, 2017 Author Share Posted May 15, 2017 Thanks so much for all of the help. I am new to this sight-obviously- and am just figuring out how to do this. I am going to try to figure out specific dimensions for my two missing pieces! Thanks again, Erin Quote Link to comment Share on other sites More sharing options...
havanaholly Posted May 15, 2017 Share Posted May 15, 2017 Erin, you can always post n introduction to yourself in the Newcomers' Forum whilst you're figuring out your missing parts. Quote Link to comment Share on other sites More sharing options...
