First Timer - Glue
14 posts in this topic
Hello Everyone! I am starting my very first project - The Orchid. I have read all the instructions thru and it states to use hot glue. However after reading several comments I see most people are using Tacky glue. Is this best? Which glue will stand the test of time? Thank you in advance for any help / advise!
Missy
Edited by Missy A
Hot glue is a no-no around here.  I have heard horror stories about houses put together with the hot glue.  I like Titebond glue, but Gorilla glue is also good.  Everyone has their own preferences and you will too after trying several different brands.
1 person likes this
Hi Missy,
Welcome.
Everyone has there own preference for glue.(NO HOT GLUE)
I have tried Gorilla glue, Titebond, and Weldbond. They all seem to hold the same. So far I prefer Weldbond because it dries clear. But most of the brands do have "dry clear options".
I am very sloppy with the glue...(working on being neater) I found having a wet rag in a Tupperware container handy helps keep my fingers cleaner. Most glues don't stain well, so you can leave fingerprints in areas and not know it until stain is applied.
4 people like this
Hot glue is definitely a no-no. In time it will dry out and the house will fall apart. I would avoid Gorilla glue. It expands when it dries and can throw off the fit.
Good idea. Baby wipes are handy for finger cleaning, too.
2 people like this
Melissa, I have an Orchid that was built with hot glue (I found it in a thrift store) with parts falling off.  I look for houses built with hot glue because I can take the heat gun to them, scrape off all the nasty hot glue, and rebuild them properly with wood glue.  I do use clear drying tacky glue for the clear plastic door and window inserts.  The first dollhouse I ever rehabbed completely was a Laurel that had been built with hot glue, and this is what it looked like when I got it:
the exterior:  beforethe interior:  before
I hope you will post us an introduction  in the Newcomers' Forum.
2 people like this
NO GLUE!! :blowup:.... I hate Hot Glue... LOL.... But like Holly said, Heating it helps get it off... I also use Weldbond or Elmer Wood Glue. The Elmers though does dry with a yellow tint so I'm careful where I use it. Can't wait to see you project!
1 person likes this
Hey Missy, welcome!
Do you have the updated instructions? CLICK
1 person likes this
16 hours ago, havanaholly said:
Thank you so much Holly! Once I figure out the website I'll get some of my beginning pictures posted!
Am I replying right to the comments? I cant figure out if I'm to select Quote?
Thank you all for your tips!
To reply to one comment, click on the Quote.
To reply to more than one comment, click on the Plus Sign for each one you want to comment on. Then click on the link that says Quote 2 (or more) Posts
1 person likes this
You can also reply in the comment box at the bottom of the Topic. The box on iPhone says "Reply to this topic". This way you are not quoting an individual, just commenting to the topic in general.
1 person likes this
You can also add to a discussion without quoting, and the box at the bottom says "Reply to this Topic" on my laptop, too.
1 person likes this
Just wanted to jump in with my three cents here: My Greenleaf (first one!) came with otherwise fabulous instructions that said to use hot glue. I quickly realized that hot glue is great for holding something in place, just a little dot here and there, while the wood glue dries. I've been spending a lot of my build time now taking apart hot glued bits, or sanding down the glue lumps, or using my Dremel to heat up the glue overspill so I can wipe it away.
Thankfully, the instructions have not lied to me any other way :)
  • Similar Content
    • Glue
      By Christy13
      I finished the outside of my house ALL of it!  Yay!  Its my first house. I have been finding amazing videos along the way. I even found what kind of paper to use to get a painted house look and big enough to not have seems. Now i am ready to put the paper on and put all the trim on, door, window, baseboard, and crown molding. However i want it still able to come off and change if i ever want it too or to access the lights. I went with the round wire lights. I have cut my grooves and taped the wires in those grooves and down. I am so ready to cover it all up now and start making the inside look as awesome as the outside!  So i need glue tecomindations that arent so perminent.
    • Cleaning wood glue off plastic windows
      By croute
      Hi all- new to this forum and building houses.
      I would like to know how you put in the windows so they don't get glue all over them.
      I also want to know what the best method is to remove wood glue from the windows. Thanks in advance!
    • What kind of glue should I use for tiny tiny bay window brackets
      By Ris
      I am building a Beacon Hill dollhouse.  I have tried to stop using hot glue ever since it was pointed out to me that hot glue won't keep as well in my dollhouse long term.  I've been using mostly wood glue, which has worked well.  Now I'm doing step Y - exterior trim.  I used wood glue last night to attach the very small, single thickness bay window brackets.  However, I just took the tape off and they snap right off with any pressure at all.  It doesn't seem like wood glue did the trick this time.  How do I get these little guys to stay put?
      Thanks!!
    • What glue is best for birch veneer siding and shingles?
      By Rindiesel
      Hello all!
      Working on the Beacon Hill and am about to put up siding. Instructions suggest hot glue but I've read many postings on this forum suggesting never to use hot glue. Instructions say to avoid using white glue due to moisture in the glue warping the siding. Then I've read in Gina's blog, she uses Aileen's Tacky glue. Any other suggestions?
    • Driving myself crazy!!!
      By tlb5000
      I have a furniture kit, it says to paint and then glue (reccomends hot glue) the furniture. So that's what I did. Idk if its me or what, but it looks horrible! My fiancé, tried building a piece with wood glue and then painting and it looks just as bad. Is there a glueing 101 I missed in school? I've never had this bad of results on other projects. Sorry, I needed to vent a little. Any glue advice is greatly appreciated.
