Elsbeth Posted June 29, 2017 Share Posted June 29, 2017 I am building a 1:48 room box. It comes with lovely marble patterned paper flooring. The instructions say "use a high gloss varnish". I am a novice builder/finisher (I usually buy my houses used and pre-finished). So what high gloss varnish will go over paper without harming it? I worry that all the stuff in my local store's home section is for heavy duty wood flooring...not paper. Help please! Liquitex? http://www.dickblick.com/products/liquitex-acrylic-polymer-varnishes/ Yay or nay? Quote Link to comment Share on other sites More sharing options...
KathieB Posted June 29, 2017 Share Posted June 29, 2017 Test a corner of the paper flooring with a bit of water to see if the colors run. If not, an acrylic varnish will work well. Quote Link to comment Share on other sites More sharing options...
Mid-life madness Posted June 29, 2017 Share Posted June 29, 2017 Maybe high gloss Mod Podge? Quote Link to comment Share on other sites More sharing options...
Elsbeth Posted June 29, 2017 Author Share Posted June 29, 2017 19 minutes ago, Mid-life madness said: Maybe high gloss Mod Podge? When I have used mod podge it seemed to remain a little tacky/rubbery feeling. I maybe used too much? I like it though for giving some little items and furniture some gloss. I want the marble floor to look glossy and have a hard finish. Hmmmm. Quote Link to comment Share on other sites More sharing options...
KathieB Posted June 29, 2017 Share Posted June 29, 2017 14 minutes ago, Elsbeth said: When I have used mod podge it seemed to remain a little tacky/rubbery feeling. I maybe used too much? I like it though for giving some little items and furniture some gloss. I want the marble floor to look glossy and have a hard finish. Hmmmm. I've experienced the same tackiness with Modge Podge. I wouldn't use it for the floor. Quote Link to comment Share on other sites More sharing options...
Mid-life madness Posted June 29, 2017 Share Posted June 29, 2017 Maybe because it is so dry out here, I haven't had that problem with other projects. I saw your Blick stuff at JoAnn's just now. What do the reviews say about it? Have you tried the Americana varnish? It is soap and water clean up. Quote Link to comment Share on other sites More sharing options...
Sable Posted June 29, 2017 Share Posted June 29, 2017 Minwax polyurethane works just fine on paper. If you are worried about colors running use the oil based one. Quote Link to comment Share on other sites More sharing options...
Elsbeth Posted June 29, 2017 Author Share Posted June 29, 2017 7 minutes ago, Sable said: Minwax polyurethane works just fine on paper. If you are worried about colors running use the oil based one. If I seal the paper just to be sure with an acrylic sealer, would the Minwax be ok? I have seen that at the store, so it would be easy to get. Quote Link to comment Share on other sites More sharing options...
KathieB Posted June 29, 2017 Share Posted June 29, 2017 2 hours ago, Elsbeth said: If I seal the paper just to be sure with an acrylic sealer, would the Minwax be ok? I have seen that at the store, so it would be easy to get. Acrylic is water based. If the ink is going to run, an acrylic sealer will make it run. Polyacrylic is water based. Polyurethane is oil based. Whatever you're thinking of using, do a spot test. Better safe than sorry. Quote Link to comment Share on other sites More sharing options...
Elsbeth Posted June 29, 2017 Author Share Posted June 29, 2017 44 minutes ago, KathieB said: Acrylic is water based. If the ink is going to run, an acrylic sealer will make it run. Polyacrylic is water based. Polyurethane is oil based. Whatever you're thinking of using, do a spot test. Better safe than sorry. I will definitely spot test. I am obviously clueless. My only problem is...the flooring is pre-cut perfectly for the kit (totally my kind of kit!). So there is no extra! lol! I will spot test anyway. Worst case scenario is that I just buy a different paper somewhere else. Thanks everybody! Quote Link to comment Share on other sites More sharing options...
Sable Posted June 29, 2017 Share Posted June 29, 2017 1 hour ago, KathieB said: Acrylic is water based. If the ink is going to run, an acrylic sealer will make it run. Polyacrylic is water based. Polyurethane is oil based. Whatever you're thinking of using, do a spot test. Better safe than sorry. That's not actually true. A water based polyurethane is available and good for indoors and an oil based is used for exterior wear. http://www.rustoleum.com/product-catalog/consumer-brands/varathane/ultimate-polyurethane-water-based Quote Link to comment Share on other sites More sharing options...
KathieB Posted June 29, 2017 Share Posted June 29, 2017 1 hour ago, Sable said: That's not actually true. A water based polyurethane is available and good for indoors and an oil based is used for exterior wear. http://www.rustoleum.com/product-catalog/consumer-brands/varathane/ultimate-polyurethane-water-based Thanks for the clarification, Sable. I was under the impression that anything urethane is oil based. I guess if you can find water-based oil paints, why not water based urethane? Science class was a long time ago! Quote Link to comment Share on other sites More sharing options...
Sable Posted June 30, 2017 Share Posted June 30, 2017 I just look at it this way, if it cleans up with soap and water it's waterbased. If you need mineral spirits or turpentine then its oil based. Quote Link to comment Share on other sites More sharing options...
My Miniature Madness Posted June 30, 2017 Share Posted June 30, 2017 I would suggest an spray sealer. I have the Mod Podge gloss one and it stinks to high heaven but never runs things - even right out of my printer and the finish is beautiful. The extra benefit is that you won't have any brush marks. Good luck into the building/crafting foray! Quote Link to comment Share on other sites More sharing options...
havanaholly Posted June 30, 2017 Share Posted June 30, 2017 Once the paper is glued down I have used regular clear lacquer on it. Quote Link to comment Share on other sites More sharing options...
shannonc60 Posted June 30, 2017 Share Posted June 30, 2017 13 hours ago, KathieB said: I've experienced the same tackiness with Modge Podge. I wouldn't use it for the floor. Me too. I never use it now. Quote Link to comment Share on other sites More sharing options...
smjsome Posted July 1, 2017 Share Posted July 1, 2017 I used Triple Thick Glaze, no stickiness. Modpodge, I had stickiness Quote Link to comment Share on other sites More sharing options...
