Need help with instructions (Beacon Hill)
17 posts in this topic
Hi, I'm trying to build the third floor but I ran into a problem.
See the red underline on the instruction sheet, I can't find the piece with that name in sheet 19. The only 2 chimney pieces on that sheet have diferent names, but the instructions say "left chimney trim" which one is it? Maybe I'm just blind but I've been searching through the sheets and I can't seam to find it.
If you have built this house and have a picture of this piece or remember the shape of it please let me know! I have the third floor in dry fit but can't assemble the chimney until I solve this :cry:
I don't want to seem obvious, but isn't this the piece you are looking for?  It might not have the same the exact same name as the instructions, but I am thinking it's this piece.  Can you punch it out and see if it works?
5a706326c3037_BeaconHillChimney.JPG.0a14
3 people like this
Colleen, Ashley's first language is Portuguese, so the label on the schematics sheet won't be as obvious to her as it might be to someone growing up with English.
Holly, she asked a question and I answered it, trying to help her find the piece she needed.  Every time I come on here and make a statement someone has to critique what I say.  This is the reason I keep my mouth shut most of the time.
I am sorry Ashley if I offended you.
3 people like this
I wasn't critiquing you.  I would likely have had the same frustrations over trying to find that piece on the schematics because of the difference in wording by the time I have gone from looking at the sheet and reading the instructions to the actual build.  I think it was helpful for you to point that wording out.
Heck, English is my first language, and I didn't see it myself until Colleen pointed it out.  :)  Sometimes, with all that tiny print, it can be hard to see the forest for the trees.  A fresh pair of eyes can be very helpful!
4 people like this
Omg you're right! :doh:
I don't know how I missed this, I guess it looked like a door or window to me lol. Thank you!!
To be frank these days I only speak portuguese when I'm not at home, my hubby and I speak english but we were both not reading the obvious here hehe.
2 people like this
29 minutes ago, wormwoodz said:
Omg you're right!
You don't know how many times I have done the exact same thing.  Look and look for a piece on the sheet, and swear it's not there.  Start looking through all of the sheets for the piece, only to find it on the sheet it's supposed to be on that I looked at the first time.  Been there, done that way too often.  Glad I could help.
5 people like this
Thank you for this information.  I haven't gotten to this point yet, but I'm sure that I would have done the same thing.  I love Greenleaf houses, but the directions and schematics often test my reading comprehension skills.
1 person likes this
Same here.
2 people like this
Sorry I need help with the instructions again :wacko:
So I've aplied most of the exterior horizontal and vertical trims, but I can't figure out where the piece circled in red is supposed to go. Also, the piece with the arrow pointed to it, I know where it goes (top left of the tower) but does this have another piece that 'corners' with it? It looks a bit odd by itself, I'm probably either missing something or I have made some mistake with the trims, thou at the moment everything looks perfectly trimmed and with the correct lenght. The only corners I haven't trimed yet are the tower left corner top and bottom (under the mansard roof, I checked pictures from other users and I don't see a trim there).
So what am I missing? Does the top left of the tower have another trim piece that is not on sheet 16? Does the long piece I highlighted go under the mansard corner between the tower and left side? And if so are people just not using it in their houses? I really wish the box came with pictures of the finished house from all angles so I could check the 'correct' trim placement.
Looked back over my BH build pics:
large.DSCN3455.JPG.d4b31273db5c767a101a2
It does look as though there is a second trim piece on that tower front left. Now this was almost a decade ago so I don't recall whether it was a piece that was in the kit or one that I added!
Yes it would make sense for another trim piece to be there, but I can't seam to find it in the sheet (at least none that says "tower"). I just went over all the trims I have glued and they are correct. This is driving me nuts, it's like I have 1 missing piece in a puzzle and 1 piece left but it doesn't fit! lol
Is it the longer one in the middle of the sheet called "Tower right front corner -Top"?
Those longer pieces are for the right corner of the tower which is already in place, I can't find the second piece for the left corner top of the tower (the one next to the mansard roof), I only find the front piece which is the one with the arrow pointed towards it. It must be on another sheet but I can't find it, I'm going to try to read everything again and check all the sheets I haven't used yet. It just seams too obvious to not be included in the set, so I'm probably missing some step.
On the other hand, after checking several pictures from other users I think I finally figured out where the red highlighted piece is supposed to go: it's this interior corner of the porch, that's why they named it "front wall right" and "bottom left corner". It's technicaly correct but so confusing when looking at the house after the porch is assembled. I've already applied siding in this area so I'm not sure it it's worth adding it at this point... I'd have to cut the sidding to fit it and just seams like a load of extra work >.<
This is what I mean when I say this house should come with more pictures from diferent angles, I was completly missing this small detail lol.
In the meantime if can't find the other missing trim, I suppose I'll have to cut a new one from spare bits.
1 person likes this
Looking through my build pics-- looks as though I added that final trim piece quite late in the game; it's very possible that I just painted a scrap piece and added it because that's the way I thought it should be...
1 person likes this
  • Similar Content
    • Beacon Hill assembly
      By missmiss76541
      My Beacon Hill in process
      I bought the kit back in 2008. I got the basic shell done at that time, but life put it to the side. This shell has moved from Texas to Missouri, back to Texas, to Virginia, back to Texas. I got a little done here and there. I finally got the box back out in the last month, I have the windows almost done, and some of the trim on. I know I'm sloppy, and I get in a hurry. I put some of the household stuff from the giant box in the rooms, not permanently, just to put something in it. I had a metal dollhouse when I was a child, which is now a collectors item, but I gave it to some random little girl. I gave her the plastic furniture with it, but everything else I kept. I've been finding and saving stuff all my life for this dollhouse, hence the giant box. I'm still undecided about the paint colors for it. Here's a couple of my favorite things, cat table & chairs, and table & chairs made from screen and springs.
      I had a friend come over a couple weeks ago, and she helped me a little bit. She said I need some people to be living in there. I didn't keep the people I had before. So, mine is going to be this cat family. For now. I printed 2 out on card stock, one with mirror image, then glue them together. No cost.
      What's funny is...I live in San Antonio, in the "Beacon Hill" neighborhood. Every other place I've lived here, I used the Beacon Hill post office. Worst post office on the planet. However, even though I live in the Beacon Hill neighborhood, they are not my post office.
    • Replacement die-cut sheets (Beacon Hill window)
      By missmiss76541
      I have the Beacon Hill kit, I bought it back in 2008. It's been in-process since then. Lately I've been doing a lot more with it. I am up to the windows now, and I should have 4 sheets of the same windows, but I only have 3. I don't know if it was never there in the kit, or if I lost it somewhere in the last 12 years.
      So I emailed Greenleaf last Monday, 9 days ago, asking if I could get a substitute sheet, someone replied immediately that yes, it's $20 plus shipping, and I needed to specify exactly what sheet I needed, which I had already done in the initial email. So I emailed right back, with the sheet I needed, and I even sent a picture of the schematic. No response...I have since emailed 4 more times, no response. I have called the company phone number countless times in the last 9 days, left messages, I've got no response. I'm stuck, I can't assemble any more until I get that sheet, the windows need to be finished before I start on the trim. What is up with this company? Someone answered me right away the first email, now I get crickets.
    • First time builder in Texas!
      By SBL
      Good Morning Everyone,
      We are getting the Beacon Hill for my daughter for Christmas for us to build together.  She loves all things miniature (as do I) and will be thrilled with the traditional style.  As a first time builder, my main question is where do we start? Is there a reference book we should have on hand, any tool kits I should buy in addition to the doll house, favorite glue? I would hate to open the box and find we need several additional items, or start and realize we should have done things in a certain order.  I am so excited and nervous to start this project with her and want to be as prepared as possible!
      Many many thanks,
      Sophie
    • First Time Builder in NYC
      By Mcannella
      Hi everyone. My name is Michael and I live in New York. I’ve been building scale model ships and aircraft for a few years but I’m brand new to dollhouse building. Last year I purchased a Greenleaf Beacon Hill kit to build for my niece who is now 5 years old. I’m getting ready to begin the project now to work on during the cold winter months. I’m hoping to have it ready for her by next Christmas.  I’ve been reading through the many excellent posts on the forum and am so inspired by all your creativity and ingenuity. I’m sure I will be back on here many times searching for answers when I get stuck along the way, but the great info I have already found on here has given me a lot of confidence to tackle this project and have fun doing it. I’ll try to share my progress as I go along.
      I hope everyone has a great weekend and I look forward to chatting with you all more in the future.
    • BH-001
      By Gleise
      I don't like mulions...
