23 posts in this topic
Hello everyone! As the title states I am new to this, but I have just purchased a partially finished Victoria’s Farmhouse. It’s basically a shell.
However, I have lots of questions!
•What tools should I get and invest in? Are there ones you wish you had when you were starting or one you can’t live with out?
•The dollhouse is missing a piece! What should I do, is there a way to get a replacement?
•The walls were not glued flush. There are gaps in a couple of places and the piece that is missing wouldn’t set flush if I had it because the roof would but up against it. There is one that is not glued on one side. How can I fix these?
•The entire outside is pairing a deep blue with bright trim. What is the best way to paint over it. I want white trim with a lighter exterior color.
•All the dowels and railing pieces are painted as well. Would it be best to sand and repaint or buy new dowels. There are over 150 pieces that are painted, mostly dowels.
Any help or resources would be appreciated!
I am trying to figure out how to post pictures but they are all to big. Any help there would be great as well!
Thanks,
Hello Dakota! Welcome, I'm pretty new to this too and I'm loving it! There are very helpful savvy minds on here. Others will weigh in on your questions. The one I can confidently answer is that I use Zinsser Bulls Eye 1-2-3 primer, you can paint it over gloss and varnish and the paint over it with any type of paint you like (I still like to sand the surface lightly beforehand though).
Welcome to the forum Dakota.:wave:
You can try to disassemble the house and then re-glue. You probably can get the missing piece from Real Good Toys.( https://cdn.shopify.com/s/files/1/0164/0860/files/JM1065_A4_6-17.pdf?5646145962560229785)
Usually heat and a putty knife can soften up the glue. I am sure other members will have suggestions for you in this area. I like Kilz primer, it comes in spray and quart sizes, but I imagine the Zinsser is just as good.
Welcome to the little family, Dakota.
Utility knife, masking tape, emery boards or  sanding block and sandpaper.  You cannot have too many clamps.  A good carpenter's wood glue.  The one I wished I'd had starting out that I'd rather not live without is my Miter Master:  https://www.micromark.com/Miter-Master
Carie answered that one.
If it were me I would take it apart and refit it.  If it was built originally with hot glue a hair dryer or heat gun wil soften the glue enough to scrape it all off.
If it's oil-based  paint I'd take some orange goo paint stipper to it and follow that up with a good sanding.  If its interior latex I'd sand off as much as will com off and prime it with something like Kilz.
Oh, heck, why  not get off as much of the old paint as you can and prime and repaint?  If you don't like how it looks, Google "spindles and balusters" to find online suppliers (I checked HBS and came up empty).
My Pictures on my computer lets me resize the photos I upload so I can post them to my albums here.  When you have made five posts you can also make albums in the Gallery.  There is a bandwidth limit to how many pictures you cqn post from outside directly into your posts, but none for the Gallery, and you can either link to your album or copy and past your album picture into your post.
Thanks,
1 person likes this
I just found “tiny turnings” on google. That’s what I typed in. Found a couple different ones. Sure would not want to try & turn them myself.
1 person likes this
Thanks for all the advice! I think this person used wood glue to join the pieces, I had tried prying gently, but didn’t want to break anything. I tried a hair dryer, but maybe it needed more time!
Thanks for the suggestions for the primer and that tool looks awesome havanaholly.
I am using my iPhone so I will have to upload some of the pics to my computer.
Mans Marcy I found tons of really cool designs, mine were just tiny dowels, but some of the ones I found know were really ornate!
Thanks again! If you think of anything else let me know!
Hi Dakota,
Maybe do some online research for glue removers. Xylene and Krud cutter.
I have never used them, so I can't offer any direction, except follow the directions and safety precautions.
1 person likes this
I’m a xylene user. Only use it outside, down wind with rubber gloves. It does the trick in seconds but use caution.
1 person likes this
Even on wood glue? I was also wondering what everyone’s work stations look like. I have this huge dollhouse sitting on the floor in my office. And It’s a little out of place.
You’re going to have to get a sturdy table to put it on. Try a hairdryer to soften the glue. Yes, xylene works on all glue but like I said, only outdoors.
1 person likes this
Ha! You really don't want to see what my workplace looks like!!!! I do a big cleanup at least once a week (usually more because one pesky piece always gets mislaid) but it just ALWAYS seems messy, but it's so much fun. Be prepared for this hobby to take up quite a bit of space :/
If you have a garage, I’d recommend starting in there on a workbench. Then do the pretty stuff inside.
1 hour ago, InfamousZim said:
...I was also wondering what everyone’s work stations look like. I have this huge dollhouse sitting on the floor in my office. And It’s a little out of place.
The one that shows in my photos was the sunroom off of our bedroom in our old house, and my work surface was an old desk and a workbench base I built the houses on my DH (Dear  Husband) made me.  After we moved he had us a workshop built and I have a regular workbench for building components and lots of shelves, as well as access to his power tools.
1 person likes this
I have used vinegar to soften wood glue. Apply a liberal amount to the joints, kind of trickling it down from a sponge.. Let is sit for a while then use something to gently pry between the joint like a butter knife, I use an old metal paint scraper.
1 person likes this
A metal putty knife assisted by gentle hammer taps will also help coax parts apart
1 person likes this
 I used lighter fluid to soften the glue. I use it for a lot of things. I use it instead of goo- be-gone (if that’s what you call it) .  It dry very fast.
Finally getting around to uploading pictures, I think anyway. It's way more complicated than it should be. :o
The previous picture is what the previous owner painted it. It is way too loud for me!
This is what it was looking like when I finally got it all apart.
This is what it is looking like now! I got this desk for $40 from Facebook just for this project!
I am currently working on making hardwood floors. I am making them out of vinyl planks! I got the idea from this:
https://www.littlevictorian.com/dollhouse-flooring/
Has anyone else tried making floors from vinyl planks?
Lol, that'd be easier than what I am doing!
Also I apologize if my photos are oversized, it's been a while since I've had to post pictures like this.
I copy and paste pictures from my albums in the Gallery here.
1 person likes this
Wow nice desk for $40 - storage drawers too! Your setup is WAY neater than mine, no matter how much I tidy it up it always looks cluttered again 5 minutes late !)
I'll have to try that, havanaholly. I managed to accidentally delete the first picture from the hosting site. :cry::cry::cry:
westPaces, I got the dollhouse for $50 on facebook too! Although I almost wish I bought it new. It's been a mess getting apart and it's missing a piece. Not to mention that paint color is too much for me.
  • Similar Content
    • Wallpapering Over Wall Hinges?
      By AlisonJR
      Hello!
      I'm currently working on my first dollhouse. I bought this already assembled and have noticed there are hinges in the corners of most of the rooms (photos attached) some of which stick out quite  bit. I am wondering if anyone has suggestions for how to hide these as I don't want them to show under my wallpapers. (it seems as if they were used to pull the corners of the dollhouse walls together)
      Thanks!
    • Handpainted Wallpaper
      By AlisonJR
      Hi,
      I am currently working on my first dollhouse. It is an Alison Jr. I am hoping to handpaint and illustrate my own wallpaper and am not sure where to start. What paper is recommended? Also wondering if a seal, specific glue is required. I was hoping to make individual entire wall sized paintings (probably with watercolour paint) that will mount to the walls as wallpaper (and won't fade over time).
    • Beacon Hill Christmas Gift
      By JennyBuilds
      Hi everyone. Thank you for taking the time to read and comment! I have read the instructions thoroughly, as well as the warm up sheet, but I am having issues differentiating which pieces are which!! They are unlabeled. Am I supposed to remove everything from the box and label? This was specifically prohibited in the instructions I read as it said to remove and use IN ORDER, but I am unclear how in step A I am supposed to locate foundation back (1) and bottom support (27)!! SEND HELP!!
    • Beginner - 1st dollhouse - Tennyson
      By jkortidis
      Greetings, I bought the Tennyson kit in a garage sale. I have 2 young great granddaughters that I am planning to make very happy with this project. Also, my husband has been open to helping me learn how to build with wood. So this will be my first project and I'm excited!
    • Tell Me About Clamps, Please
      By HotPinkGlitterSparkle
      I know I will need clamps, but I'm trying to figure out how many of each kind/size I should have on hand as I get started with my Orchid.  At Hobby Lobby I was unable to find any of the plastic bar clamps like those blue ones for dollhouse building I see in photos, so I presume I will need to get them online.  I want to make sure I purchase enough, and truly appreciate your input.
      http://www.ebay.com/itm/Plastic-Clamp-small-tools-model-miniatures-hobby-2pcs-12333-/161729392960?hash=item25a7d2b140
      http://www.ebay.com/itm/Plastic-Clamp-7-1-2-tools-model-miniatures-2pcs-/160503334789?hash=item255ebe8785
      What other sorts of clamps would you recommend having in my toolkit as I begin?
      Thanks!
      faye
