Beacon hill bay windows
10 posts in this topic
Hi!
Has anyone ever attempted to build the bay windows and THEN install them on the house? Did it work, what were the difficulties and adantages of doing it this way - if at all possible?
If you're going to decorate the bay, isn't it easier to do it before installing the windows?  I would do the dry fit, assemble the bay, decorate it, assemble the windows and install them, and then install the assembled bay.
Hi Janet............I haven't built a large number of windows and bay windows, but i assure you that building the window outside and then installing is the way to go. I also hand build doors outside and then install.
Thanks guys. That's how I'm going to do it. I just did a complete dry build and it will work. Wish me luck :)
Between splopping paint/ stain/ paste everywhere and not being able to compress my hands into small spaces I always assemble doors and windows and wait until last to install them.
Holly I hate to work in confined spaces - brings out the swearer in me! When you say 'until last to install them', when is last? I've been going about this as decorate as you go, I plan to brick the outside walls - should I do that before or after I put the windows in?
I also usually decorate as I go.  Before I start I lay the door frames around the doors and the window frames around the windows and trace around them onto the wood, sometime before, during or immediately after the dry fit.  I then cut pieces of masking/ painters' tape into narrow strips and mask off those areas where the frames will go (so when I finally get to the doors and windows I'll be gluing bare wood to bare wood).  When I've finished decorating an interior wall the interior of the window or door frame goes up; interior doors are hung.
I butt exterior wall treatments up to the tracing lines.  Since I usually "plaster" or "stucco" my exterior walls, I also mask off the frame areas and window surfaces until I've slathered spackle/ drywall mud/ joint compound on and messed with it to get the finished texture, and then I remove the masking tape.  In the case of brickwork (like on my Glencroft pub) or siding I butt to the traced line.  Then when everything is dry I glue on the exterior frames and hang the exterior doors.  That's what works for me; some other order might work better for you.
2 people like this
Sounds great Holly, that's pretty much what I've been doing and what I had planned to do but I wasn't sure if it would work :) I plan to extend the kitchen and thought I'd leave that to last as I'm not yet sure how I want it to look...
Scrounge some pieces of cardboard to make mock-ups of the pieces you'll need to make your extension and you can use them as patterns to cut the wood.
I hadn't thought about doing that. I use Sketchup but there's nothing like an actual model! I'll let you know how it goes.
  • Similar Content
    • Finish building The BeaconHill
      By NJ Mitchell
      Hi I live in upstate NY, Albany area and I’m looking to hire someone to finish building my daughters dollhouse, The Beacon Hill.  It was started about 8years ago, but the gentleman that was working on it passed away.  I estimate that it is about two thirds to almost three quarters of the way complete, it’s mostly the windows and trim, finish work that needs to be done, painting, wiring some wall paper and flooring, etc.  Does anyone know of anyone that I could hire to complete it?  I’m willing to take it to towns within a 1-2 hr Drive of Albany to get it completed.
      Please contact me via email at njmitchell529@gmail.com thanks.
    • Mystery dollhouse
      By Verdi
      Hello, i an hoping someone can help me identify a dollhouse.
      The house is customized by artist Julien Martinez, I put is link further down on this post. I am looking for my first dollhouse, and this one would be perfect, with its glass roof in the attic and ok sized rooms.
      It does not have to be this exact one, but I am looking for a mainsard roof empire victorian (french/colonial/new orleans style) , with a minimum of 4/5 rooms. Preferably not so large, and also preferably already built, as my main interest is spending time creating the dolls and accssories to go with it.
      Edit: I am also interested in a beacon hill house, but I think the kitchen might be a bit on the smaller side. Still, if anyone has one for sale, let me know.
      If anyone could point me in the right direction, I would be very thankful.
      http://www.google.no/search?client=ms-android-samsung&dcr=0&biw=360&bih=282&tbm=isch&sa=1&ei=cWxgWpL5BsKvsQHdwa-oBw&q=julien+martinez+dollhouse&oq=julien+martinez+dollhouse&gs_l=mobile-gws-img.3...2543.5366.0.6712.10.7.0.3.3.0.313.1808.0j1j4j2.7.0....0...1c.1j4.64.mobile-gws-img..0.9.1888...0j41j0i30k1j0i13k1.0.f7qMQehXvEk
      Best regards
    • Kitchenette additions
      By MLI Designs
      finishing touches of kitchentte. Using jewelry finding for light pendants and wine bottle holders on each side wall.
      im not thrilled with trim around window so think I'll find a different wood and matter ends.
      Legs on bar look cracked because nothing is secured down
    • How would you make this?
      By MLI Designs
      @MikeUK finally remembered what I wanted to ask you. I'm sure there are others here who could answer this too.
      if you were going to replicate this chair stool, how would you do it?
      I want this style for my kitchen. I'm waiting for a solder tool I order but that won't be here for awhile
    • Rounded Doors and Molding
      By MLI Designs
      I couldn't figure out what to do with the door (I didn't like the plan wood door included with the Sugarplum) so I decided to make a unique door with polymer clay. But now I'm having the problem of molding. I want to do molding around door but not quite sure how to achieve the rounded top. Amy suggestions?
      Also, what do you use for Windows?
      thanks in advance.
      BTW, the polymer clay worked like a peach for anyone who is having a similar problem. Great way to create your very own piece (for whatever)
