Fairfield wiring
20 posts in this topic
Help! I took on the wiring of my Fairfield dollhouse. The problem is with where to put the wires on the lights & the tapewires. I have looked at the house over & over. I just can’t figure out a way to make it work!
Is the house already assembled?
Here's how I electrified my Fairfield: http://www.emilymorganti.com/blog/?p=8830
The third floor has floor lamps (not shown in those pics) and the other floors have ceiling lamps with the wires attached to the tape in the room above. The entry has a sconce with the wires pulled through to the kitchen.
2 people like this
Dear Pam...….I must admit that I have never installed tape wire in a house that had all four finished sides, however, I have done some extensive reading on the subject.  Take note of the wiring method in my album.  What ever you take photos with a ruler so you know where your tape is.  You can make a right or left turn by using a folded corner.  Make sure all your brad fastened joints are double bradded or if using small eyelets, use double.  You may want to run your upper tape under the flooring. Keep in mind you may be able to make your flooring so it can be slid out to make repairs. Tape wire can be run under wallpaper, however, you would be well served to run it near an outside edge where it could be hidden by trim or at least where you could replace a narrow strip if required.  Bradded intersections are a real trouble area. Less is best.  I whish I could be of better assistance. Take your time when planning your wiring and take lots of photos.  Search on line for alterative intersection connections.
Silver Dollar Out
1 person likes this
The Lily is kind of the same odd opening layout.  Like Kathie said,  ceiling lights on first floor with the tape on floor of second floor.  Then from those you can make runs up the walls or around baseboards for 2nd floor lighting
1 person likes this
7 hours ago, Sable said:
I really learned a lot from this video. She placed the tape toward the front instead of along the walls:
https://m.youtube.com/watch?v=VaswR0TcQRE
Excellent video, thanks Sable. Despite having electrified a few houses, I learned a lot. I took notes and am inspired to do the electric in the Beacon Hill as the next step. For some reason, I've been shying away from doing any more construction.
This is exactly what I needed! Thank you so much Sable! I am finally ready to tackle the lighting. I think I will start it under the bay window of the living room. She made it so easy to add ceiling lights. Thank you for posting this!
Ok...I officially hate this dollhouse!!  I have spent 2 months & HUNDREDS of dollars & today another light broke. I was trying to super glue it back together & my lights quit working all together. I used the tester & there is no power going to the dollhouse at all. I have spent 12-hour days trying to finish this house. I had the wiring in, ceilings finished, wallpaper & mopboard on, stucco, outside windows painted & glued on. I started putting on asphalt shingles, which is a major pain. I was just waiting for a new light to arrive - which is the second light that has burned out. I can’t find replacement bulbs & I have to buy the tiny little lights from England or Canada! I can’t put down the flooring in some of the rooms until I replace the lights & the little pin in my awl broke. This dollhouse is costing a small fortune! I hate the 1/24 scale furniture (tried one of the Greenleaf dining room kits & hate that). I’m sorry to be so hateful but I’m almost in tears! I can’t believe I can’t finish this after all this time & money spent on it. Anyone have any advice or sympathy? Thanks!
I can sympathize!!! I am fairly new to building and the electrical is the bane of my existence......Here is my most recent Blog post https://livingtheminiaturelife.blogspot.com/2018/07/the-tale-of-two-lights.html
PLEASE check the Junction Splice . Most of my issues are from that Godforsaken thing! Just remove it and then reattach it in a different spot....that is a good trouble shoot, then if that is not the culprit, go back to the last light, or eyelet, or whatever you did last. I have put in a new fixture and the whole house wouldn't work until I remove it and redid it. Don't give up on your house, you are not the only one feels this way. (((HUGS))))
P.S. Sometimes if you threaten the house with a lit match, it becomes more cooperative.....then walk away and do something little.
2 people like this
Thank you so much for understanding! I thought about what you said & went back to the light that broke. I took out the eyelets & the lights came on again. I guess the house can live another day but I’m keeping the torch close! Now to order another light, some lightbulbs (that may or may not work) & a new pin for my awl. Thanks again!
2 people like this
I sympathize as well. I admit I didn't even try to electrify my Fairfield. It has battery lights now. I also agree the junction splice may well be the problem. I hate those #$&&_# things. Please, please don't give up. I don't know what shipping would be to where you are, but Mini Etchers has some nice kits for Victorian furniture that are quite reasonable. I also really like Jane Harrop in the UK.
2 people like this
Pamela, do NOT take your lighting frustrations out on the poor little Fairfield.  I do not electrify any of my builds, and I enjoy playing with them just fine without.
1 person likes this
Many times small bits of the clear tape on top of the tapewire gets pushed into the hole where the copper is trying to make the connection to the eyelet. I peel away as much of the clear tape to expose more copper so the eyelet has a full connection. Basically, I cut a small square of the clear tape off where the eyelet will be inserted. This had prevented all problems.
2 people like this
Take a deep breath! Everyone who has ever electrified a dollhouse has felt like this at some point!
From what you described it sounds like your broken light may have caused a short circuit. It's good that you removed it. I had a similar experience recently but the wires (which were underneath the house, so I didn't see them) actually started burning up. I was lucky I unplugged it when I did, or it could have caused a lot of damage.
If you continue to have problems with the lights all going out, the junction splice is very likely the culprit. As I was fixing the electricity on my house (after those wires burned up) I sometimes had to jiggle the junction splice to make them work. I've also sunk hundreds of dollars and a lot of time into the electricity on this house and have promised myself I will never electrify another dollhouse, but I felt like I couldn't leave this one halfway done. I recently had to replace the lights in two rooms where the opposite rooms were already finished, so I couldn't run the wires through the wall/floor. I got creative and used a "false ceiling" for one of them, and in the other I found a way to hide the lights behind my staircase. There are always creative solutions for these sorts of problems -- and it sucks when the electricity doesn't work, but coming up with a genius fix can be so satisfying! And turning on the lights and finally seeing them all work is such a great feeling. It'll be worth it. :)
What type of bulbs are you looking for? Half scale lights with replaceable bulbs usually use the bi-pin "micro bulbs":
https://www.miniatures.com/Four-Bi-Pin-Micro-Grain-of-Rice-Bulbs-P19331.aspx
https://www.miniatures.com/Four-Bi-Pin-Micro-Candle-Flame-Bulbs-P19332.aspx
If you're using 1:12 lights with screw-in bulbs, Miniatures.com carries several styles of those as well.
There are a lot of great options for half scale furniture, both kits and already finished, you just have to look a little harder to find them. Here are some good sites:
http://sdkminiatures.com/
http://atriflesmall.co.uk/
https://www.mountainminiatures.com/
Also this seller has a good selection of 1:24 Bespaq up on eBay right now: https://www.ebay.com/str/fjdebbie/1-2-SCALE/_i.html?_storecat=10344219017
1 person likes this
Thank you so much everyone for the support, encouragement, advice & links! I finished the house (but want to replace the paper flooring.)
the problem was a burned-out bulb. I had to replace several (which took HOURS) but then the lights came back on. I still have a burned-out bulb in the entry & I’m not sure how I’m going to get to it to replace it!
The next thing that happened was a tree limb broke off in a storm & landed on the main power line. They had to shut off my power to get the limb off & then replace the mast where the power lines connect to the house. The only damage was to my transformer. I replaced it & now everything is good! I think the next dollhouse will be a 1:12! Thanks again!!
1 person likes this
You could just leave it out. When do we ever turn on ALL of the lights in our real house at the same time?
As an aside, the 2-1/2 year old has figured out how to turn on the lights in the real house. She can finally reach the switches. She goes around turning them on, and Grandpa follows behind, turning them off. Then she starts all over again. Keeps them entertained for obscenely long periods of time. :D
1 person likes this
Can I ask where you found battery lights small enough for the Fairfield? I've been searching, as I have no interest in trying to electrify mine, but feel like having no lights at all will be disappointing, an seem to only be able to find battery lights in 1:12 scale.
It’s because the coin batteries are out of scale.
EDIT: oops  I was wrong. There are just a few here with coin batteries;
https://www.miniatures.com/124-Scale-Lighting-C387.aspx?s=AverageReview%20DESC&c=387&ps=12&p=1
  • Similar Content
    • Doll's houses for Christmas
      By Littlehousesplus125
      You might like to look @ this if you were lucky enough to get a doll's houses at Christmas
    • New in Wisconsin - Starting with a Fairfield Build
      By SimPenguin
      Hi! I’ve been lurking a while but think I’m ready to commit now. ;) I haven’t built a dollhouse before but have done a lot of diorama building in 1/6 scale. I didn’t *intend* to build a dollhouse, but a few weeks back I was randomly googling around and saw someone’s Fairfield build and instantly knew it was the right house for me. I don’t think I can post pictures yet so I’ve started an album at my Flickr here: https://www.flickr.com/photos/144333381@N04/albums/72157711471679943. Just a few pics now of my dry assemble. It’s probably going to be a while before any real construction starts as I am waiting for supplies and designing things. I have some structural changes I want to make and have a little more “how to” knowledge to gain before I tackle it. Until I have a good plan laid out I will probably hold off starting anything too involved.
      Thanks to all of you amazing people for your extensive posts/discussions – I have learned SO MUCH already from the experiences of others who have gone before me!
      - Melissa -
    • Fairfield Rehab
      By Sassley
      Today I brought home a very used Fairfield that is in need of a lot of TLC. Would love tips on
      1. Possible disassembly to make decorating easier/ suggestions on opening up the tower room...or not. I wanted to reconfigure the staircase but that looks impossible- although I’ve seen it done with this model, hence why I’m asking about disassembly. Also wondering what tools are best for cutting into wood cleanly, assembled or otherwise.
      2. Electricity: I have a tape wiring kit but have never done it.
      House has been cleaned and sanded. Figuring out swatches for exterior paint right now. I have a basic outline broken down chronologically and room by room. My goal is to have electricity working and the exterior painted by mid October 2019. After that I will focus on one room at a time.
      Thanks for your help! I look forward to getting to know you all.
    • Tape Wire - What lights do I use?
      By JenColes
      Good day! This is my first post in the forum - go easy on me!
      I'm an absolute beginner, currently building a 1:18 scale recreation of a local heritage house that was torn down 4 years ago. So far things are going well, but like MANY miniature newbies, I am absolutely confused by the wiring aspect of the build.
      I have done as much internet research and forum reading as I can, but I'm still not sure if I'm doing the correct thing.
      So, here it goes. These are my supplies:
      Cir-Kit Basic Wiring Kit
      Transformer (FIFODR® 12V 5A 60W DC Power Supply Adapter(Input 110V-220V,Output 12 Volt 5 Amp 60 Watt) DC Converter LED Driver Lighting Transformer for 12V 5A Flexible/Rigid 5050/3528/2835/5630/5730 LED Tape Strip Light FD-ADP60W)
      Lights (Pre Wired DC 9-12V 3mm Water Clear LED Diodes White Light)
      First question: Will the lights I purchased work with the tape wire kit?
      Second question: I will obviously need to purchase extension wire for the lights - what type of wire am I looking for?
      Third question: My house is mostly foam core on the inside, but the outside walls will be wood. I'm thinking of only installing the tape wire to the wood outer structure and laying/hiding the wire through the house, linking to the outside tape wire (does that make sense?). Will that work?
      Thanks in advance for any help you can provide!!
      Cheers
      Jen
