Mineejv Posted August 21, 2018 Share Posted August 21, 2018 I’m having a hard time getting the right angle on my stairs hand rail. I’ve cut it at a 45 but it doesn’t seem to fit good. I’ve cut it at a 30 degree angle ,that didn’t work. I don’t know how to measure to get the angle (angles) that you would use on something. I have just enough to finish up the stairs rails, I’m not ready to order online right now. I’m trying not to use it all up getting the angle I need. Quote Link to comment Share on other sites More sharing options...
Mid-life madness Posted August 21, 2018 Share Posted August 21, 2018 I am no help at this, and asked my husband to help me when I did mine We/He eyeballed it like a dry fit. The cut was actually steeper than I thought it would be....but I found this online. https://www.youtube.com/watch?v=T_r2n8Mf8YY There are several more how to videos etc....I didn't do a deep search. 1 Quote Link to comment Share on other sites More sharing options...
fov Posted August 21, 2018 Share Posted August 21, 2018 Does this help? https://www.calculator.net/triangle-calculator.html Insert 90 degrees for angle A, your ceiling height for side b, and the length of your staircase for side a, and leave the others blank. 1 Quote Link to comment Share on other sites More sharing options...
havanaholly Posted August 21, 2018 Share Posted August 21, 2018 I take a sheet of used copy paper and lay it against the staircase with one edge even with the floor and move it until I can press the top of the paper along the edge or the steps with my finger and fold along those marks to the lower corner, I use this to mark the angle to cut for the ends of the banister/s. It's similar to the way I get the angles to cut shingles for where gables & dormers join the main roof. Quote Link to comment Share on other sites More sharing options...
Mineejv Posted August 21, 2018 Author Share Posted August 21, 2018 I’m going to try it that way...... I’ve cut a 45- 40 35 30 degrees I need it to go the other way ( if that’s possible) it’s for the Pierce’s that has 4 different size railings. I have one cut right (I hope,it’s not glued yet) that i cut at a 45. I’m thinking I need to do it another day ! Quote Link to comment Share on other sites More sharing options...
KathieB Posted August 21, 2018 Share Posted August 21, 2018 1 hour ago, Mineejv said: I’m thinking I need to do it another day ! Actually, that's a very good plan. Sometimes stepping away from a challenge for a day or so can make all the difference. Quote Link to comment Share on other sites More sharing options...
