Ldecs Posted October 27, 2018 Share Posted October 27, 2018 Hi again! Making some progress on my Duracraft VM800 and have a question. I’m ready to paint the outside, but some of the window mullions are broken. They’re made of wood, and I’m trying sawed off toothpicks now but am having a terrible time getting them to stick together. Tried wood glue and tacky glue, they’re just so tiny! Any genius tricks out there? Can’t post a pic, no matter what I do it always says the photos is too big. Quote Link to comment Share on other sites More sharing options...
Qubanqtee Posted October 27, 2018 Share Posted October 27, 2018 Hi! I would try using a small the strip from Hobby Lobby - or another hobby supply store that might be in your area.....also, if you haven't looked on Ebay, try Manchester Woodworks...he has a lot of the trims used for Duracraft ... which most of those trims were cut to size by the person building the house so if you have the instructions it'll tell you what size the LPL Trim size was for the mullions ...hope this helps. And I hope you get the picture thing resolved soon...you should try reaching out to a moderator for some help =) Quote Link to comment Share on other sites More sharing options...
Sable Posted October 27, 2018 Share Posted October 27, 2018 The best thing to do is to is a Dado cut on the two pieces which will join together. This makes a solid square joint. 1 Quote Link to comment Share on other sites More sharing options...
Mid-life madness Posted October 27, 2018 Share Posted October 27, 2018 Try mixing a little super glue into the wood glue, then spray with super glue accelerator. 1 Quote Link to comment Share on other sites More sharing options...
Qubanqtee Posted October 27, 2018 Share Posted October 27, 2018 1 hour ago, Mid-life madness said: Try mixing a little super glue into the wood glue, then spray with super glue accelerator. You are so brilliant! 1 Quote Link to comment Share on other sites More sharing options...
Lita Posted October 27, 2018 Share Posted October 27, 2018 3 hours ago, Sable said: The best thing to do is to is a Dado cut on the two pieces which will join together. This makes a solid square joint. @Sable, I am dealing with a similar problem and I like this solution. How do you make a dado cut on tiny pieces of wood??? Quote Link to comment Share on other sites More sharing options...
Ldecs Posted October 27, 2018 Author Share Posted October 27, 2018 Thanks everyone! Was able to make it work with toothpicks, gorilla glue and a lot of patience :) Quote Link to comment Share on other sites More sharing options...
Sable Posted October 28, 2018 Share Posted October 28, 2018 1 hour ago, Lita said: @Sable, I am dealing with a similar problem and I like this solution. How do you make a dado cut on tiny pieces of wood??? I use a mini table saw with the blade just peeking out but I’ve made tiny dado cuts using an Xacto knife to cut out the sides and a nail file or small filing tool to get the center out. You have to cut out a square piece 1/2 into the wood. Quote Link to comment Share on other sites More sharing options...
Lita Posted October 28, 2018 Share Posted October 28, 2018 1 hour ago, Sable said: I use a mini table saw with the blade just peeking out but I’ve made tiny dado cuts using an Xacto knife to cut out the sides and a nail file or small filing tool to get the center out. You have to cut out a square piece 1/2 into the wood. Perfect! Thank you. Quote Link to comment Share on other sites More sharing options...
kokomo Posted November 7, 2018 Share Posted November 7, 2018 On 10/27/2018, 12:37:12, Mid-life madness said: Try mixing a little super glue into the wood glue, then spray with super glue accelerator. I'm a little late to this thread but I was wondering about the accelerator. I've never heard of it but it sounds great! If you spray it on the wood after gluing does it leave a residue that can't be stained very well? I know if you're not careful enough with super glue it can leave behind spots that I've found nearly impossible to stain. Just wondering if that's the case with the accelerator. Quote Link to comment Share on other sites More sharing options...
Mid-life madness Posted November 7, 2018 Share Posted November 7, 2018 1 hour ago, kokomo said: If you spray it on the wood after gluing does it leave a residue that can't be stained very well? I mostly use the accelerator to bond stained and varnished pieces that have broken and won't adhere with plain wood glues. The accelerator seems to vaporize quickly, and I can't remember it repelling stains.....Usually it is the actual super glue or wood glue that I have been sloppy with that i have problems with. I think this might be time for some experimentation to make sure. Quote Link to comment Share on other sites More sharing options...
kokomo Posted November 7, 2018 Share Posted November 7, 2018 Well I'll keep my eye out next time I'm in the glue section. It's not that expensive so I should just grab some if I see it. I think it's a brilliant idea and if it works without a mess that would be great! Quote Link to comment Share on other sites More sharing options...
NellBell Posted November 7, 2018 Share Posted November 7, 2018 Glad I saw this post I’ll be trying the acc keratotomy on a broken leg I have Quote Link to comment Share on other sites More sharing options...
havanaholly Posted November 7, 2018 Share Posted November 7, 2018 12 minutes ago, NellBell said: Glad I saw this post I’ll be trying the acc keratotomy on a broken leg I have I would think a cast might work better... 1 Quote Link to comment Share on other sites More sharing options...
NellBell Posted November 8, 2018 Share Posted November 8, 2018 8 hours ago, havanaholly said: I would think a cast might work better... How do I do a cast ? Based on what a cast is I kinda get it but what do you use ? And I have no idea how the word accelerator changed to the crazy word that was posted. Quote Link to comment Share on other sites More sharing options...
KathieB Posted November 8, 2018 Share Posted November 8, 2018 10 hours ago, havanaholly said: I would think a cast might work better... 1 hour ago, NellBell said: How do I do a cast ? Based on what a cast is I kinda get it but what do you use ? And I have no idea how the word accelerator changed to the crazy word that was posted. I think Holly was giving a tongue-in-cheek response to your statement about using the accelerator on "a broken leg I have" ... she seized on the fact that you didn't mention that the leg was on a piece of furniture to ring your chimes in good fun. As for the crazy misspelling, no doubt our friend Auto-correct was involved. Quote Link to comment Share on other sites More sharing options...
havanaholly Posted November 8, 2018 Share Posted November 8, 2018 Thank you, Kathie. I'm sorry, Nell; I was an English minor in college long before I became a nurse and your broken leg caught my eye (I did ignore the keratotomy, though). Quote Link to comment Share on other sites More sharing options...
NellBell Posted November 8, 2018 Share Posted November 8, 2018 Thanks Holly for the early morning chuckle. Made for a great start of my day. Quote Link to comment Share on other sites More sharing options...
Qubanqtee Posted November 8, 2018 Share Posted November 8, 2018 hahahahahahaahaha. Quote Link to comment Share on other sites More sharing options...
