Tape Wire - What lights do I use?
Started by
JenColes,
5 posts in this topic
Recently Browsing 0 members
Similar Content
Wall Sconces and adapters -Rookie mistake
By fleabags3
OH MY. I'm a doof. I took a loooong break from minis and am firing it up again, but have had to refresh on many things. I did the biggest rookie mistake. i spent so much wasted time meticulously installing wall sconces so the wires were under wallpaper and just realized they make ADAPTERS for them. i'd only done ceiling lights and wall plugs. duh me. They look good but such a royal pain to noodle it all through the hardest way possible. ugh
Doll's House Lighting upgraded our information
By Littlehousesplus125
Doll's House lighting we have just upgraded our information to help you wire your doll's house http://www.littlehousesplus-shop.co.uk/Dolls-House-Wiring-for-Lights-Fires all the information you need don’t need white plugs
eyelets for wiring
By kemck
Hi everyone,
It has been a few years since I've been on the forum. I was working on wiring the Arthur, ran into a frustration point, and life got busy, but... time to finish this project (or at least make progress again!). To avoid trying to pound an eyelet into the weak upstairs wall of the Arthur I tried using a manual drill someone suggested, but the eyelet connections are really loose and there is not electrical connection in the joined wire because I couldn't hold the drill steady enough (I did try to use the block of wood that came with the drill for support). Is there anything I can do to salvage the connection I tried to make or do I have to try to make another one? If I do have to re-do it how can I avoid the same mistake in the future? Thanks!
Fairfield wiring
By Gramma Pam
Help! I took on the wiring of my Fairfield dollhouse. The problem is with where to put the wires on the lights & the tapewires. I have looked at the house over & over. I just can’t figure out a way to make it work!
