Sign in to follow this
Followers 0
Fairfield Rehab
3 posts in this topic
Posted (edited)
Today I brought home a very used Fairfield that is in need of a lot of TLC. Would love tips on
1. Possible disassembly to make decorating easier/ suggestions on opening up the tower room...or not. I wanted to reconfigure the staircase but that looks impossible- although I’ve seen it done with this model, hence why I’m asking about disassembly. Also wondering what tools are best for cutting into wood cleanly, assembled or otherwise.
2. Electricity: I have a tape wiring kit but have never done it.
House has been cleaned and sanded. Figuring out swatches for exterior paint right now. I have a basic outline broken down chronologically and room by room. My goal is to have electricity working and the exterior painted by mid October 2019. After that I will focus on one room at a time.
Thanks for your help! I look forward to getting to know you all.
Edited by Sassley
Ashley, if the kit was built with hot glue a blow dryer and a metal paint scraper to remove the softened glue will be your best friends.  I built two Fairfields to be halves of a Bar Harbor "summer cottage" and turned one of the tower rooms into a utility bathroom by cutting a doorway into the wall, using cardboard to make templates to extend the tower walls to join up with the attic and cut my own 1/8" thick plywood pieces using the templates as patterns and I made the tower roof removable for access.  I hung a Foucault's Pendulum from the roof of the second tower and cut holes in the second and third floors for it.
1 person likes this
Thank you so much! That’s a brilliant tip. I never would have thought of that.
The Foucault’s Pendulum idea is really unique, too!
Followers 0
  • Similar Content
    • Fairfield, McKinley, Garfield - Between Santa Fe and Albuquerque
      By Talina
      I have two partial kits-Fairfield and McKinley-free. I also have a Garfield that has been started. Whoever started it has done a beautiful job so far.all the punched out parts are bagged and labeled. Not really shippable,but willing to meet people part way (located between Santa Fe and Albuquerque). Want a totally reasonable amount. Mostly want it to move on. Contact me for pictures,as I don't seem to upload pics.
    • Can I paint walls inside instead of wallpaper
      By ShazNZ
      Hi. I’m new to miniature building and have bought a Fairfield dollshouse. I was thinking I would try and create a modern farm house style for the interior of the house using one neutral colour throughout with white trim. Can I paint the interior walls instead of using wallpaper??? I know if it did this I would need to putt the joins in the corners and sand smooth. Then paint over the corner joins.  Does this work? Would it come up ok or does it look crap painting interior? Any thoughts or advise?
      Also can I use a water based enamel paint.......as I have this nice colour paint left over from when we built our own house.?
    • Fairfield Flooring and Wallpaper
      By LeFemmeFatale
      Me again!  SO. I've finally created all my custom wallpaper and printed them all out. I also have started cutting down and staining all my individual coffee stirrers for my flooring.
      My question is this: for the Fairfield, since the layout is so complex, I can't figure out if it would be better to lay the flooring down before I put up the walls, or to wallpaper and assemble the walls before I install the flooring? I know everyone says it is preference, and that if you dry fit, you'll be able to see tricky spots before you do it, and decide that way...but for me, the whole thing seems tricky hahaha. Also, I am not wiring for lighting, so that component doesn't matter either.
      Is there a benefit to doing wall assembly first vs. floor first or vice versa? I am going to paper the walls before I install them in either case, if that makes a difference.
      Thanks friends!
    • Hello from Rhode Island
      By LittleHouse
      Hello! I'm new here.  Some things about  me:
      I have always loved miniatures.  As a child, I had a large Ginny doll collection, a treasured dollhouse baby from Germany, and lots of little plastic dolls from the dime store.  When I learned to read, “The Raggetty Paggetty Dollhouse” and The Borrowers were favorites. This is my first dollhouse. I’ve come close to buying one many times, but nothing was ever quite right.  Then I saw The Fairfield! It was love at first sight. I like the way its rooms are at angles and not just a set of boxes lined up in a row.
      I’ve already been browsing the posts of Fairfield builders on the forums. I love the suggestions and advice and seeing all the different ways of doing things.  So far I’ve made the base and the staircase and done LOTS of dry fitting.  I hope to use what I’ve read to make my first dollhouse a good one, but I hesitate to take a step that can't be undone!  Sometimes I think: Hmmmnm there may be something to be said for those houses that look like a set of boxes lined up in a row ;-)
      Linda
    • Refinishing 1:24 scale furniture
      By LeFemmeFatale
      So, I've found a source for a bunch of 1:24 scale furniture for a decent price, but the problem is, I don't love the finishes. Originally I was thinking I would just paint them all so it wouldn't matter, but because they are hand-carved wood, I'm now thinking it would be nicer to stain them all. Is there any way to do this without destroying them? I mean, half scale is so tiny, is it even possible to sand the current paint/stain off of them in the first place?
      I don't want to buy them unless I know I can refinish them, because it's an investment of over $400 (oof this is a pricey hobby!)
      Thanks all! <3
