Sign in to follow this
Followers 0
Do You Believe in Siding After a Build?
19 posts in this topic
Hi everyone! I've had a long quiet period on here, but I've been steadily working away and going to shows/shops (I was at Good Sam in San Jose and was fortunate to visit Dollhouses, Trains, and More in Novato, CA for their closing sale). I will, finally, post a batch of haul and progress photos in the first week of November, when I get settled back into my home in Eugene. I really am terrible with a camera and it bugs everyone I know! In the meantime, I have a question:
Has anyone ever tried adding siding after their build's exterior was complete? Still being a novice, when I finished my first build (the Orchid; the interior is still a work-in-progress) I stepped back and thought 'I think I should have done siding.' Especially with the shingles on, the level of detail on the exterior just varies too much; it's been irritating me for a couple of months now. I'm a bit of a stickler it seems (though I didn't know it at the time)! My window/door casings, dormers, gingerbread, and my custom porch/railings are all already in place. I realize it may be very difficult, but the question is: is it even possible? If so, do you have any tips on how to do this?
Any and all possible mini wisdom is welcome!
P.S. I have the opportunity to snag a very affordable Laurel kit secondhand so I'm trying to decide where I should just start the next building with siding and call it 'lesson learned' or go back and add to the Orchid (and stash the Laurel until after the New Year, space is a very important consideration here). P.S. P.S.: I'm not a Cher fan, but I took a page out of Elizabeth's book (Studio E miniatures) since I'm always charmed by her ability to make musical jokes in her posts/titles!
2 people like this
Thanks for implanting that song in my brain....I'll be singing it all day.:eek:
Can you pry the trims off of the outside using heat and a putty knife?  That is my suggestion to make it easier.
You can always give it a try, and if it is too difficult stop. Are you using the Greenleaf individual planks or the clapboard siding sheets?
My only suggestion would be to mark the walls with horizontal lines to guide placement to keep the strips even all the way around. Then cut one strip at a time to fit, butting it against the trims. I wouldn't take the trims off, as I probably wouldn't do a very good job of it and would end up with some bits of siding butting nicely and others going to long or too short. Either way, the look would not be good.
If it were me I would invest in some sheets of inexpensive posterboard and cut them into siding strips and begin laying them at the bottom edge, cutting to fit as I go.  Once the strips are firmly glued into place, primed and painted, who will know?
Thank goodness I'm not the only one!
1 person likes this
I had imagined used the clipboard siding sheets, but now that I think about it invidual planks (though more time consuming) will probably be easier yo work with in this case! I'm not entirely confident that I can safely pry my casings up though. With the strips it may be easier to work around them.
This sounds like a good idea, Kathie! I think I might take your advice. I found that guide lines were indispensable for shingles so it makes sense they would help here too!
I like Holly's foam idea (you're so very thrifty!) but I'd like to at least give wood a try. Does anyone have a preferred kind/brand of siding planks to recommend?
Thanks for the advice everyone!
4 hours ago, third_hand said:
I like Holly's foam idea...
NOT foam core, posterboard in the $ stores is a lovely stiff card stock.  I truly love the Greenleaf siding strips, which I have also used for flooring and beadboard wall covering.
1 person likes this
Yes, I have on several houses. I'm also the weirdo that wallpapers AFTER building the house...
I've definitely sided once the house is built, but I've never had the courage to wallpaper after building. Kudos!
1 person likes this
I never know what I want to do until the base structure is built, so...
I'm with Linda.  The house doesn't usually tell me how it wants to look until it's in dry fit.  Then the only time I paper before assembly is somewhere like a stairwell or other tight area I'll never fit my hands into once it's together with glue.
Tell me about it.  Ms. Beacon Hill has told me she wants to have wooden siding painted in a half dozen colors -- six different times, not all at once. She has also demanded brick with stone quoins and,or stucco at various times, sometimes musing about board and batten beneath the bay windows. Currently it is holding out for a brownstone skin. If only she would make up her mind ...
1 person likes this
I'm so glad you specified.  I had started envisioning this:  https://www.rocknrollbride.com/wp-content/uploads/2014/05/san-francisco-honeymoon-travel-guide19-576x768.jpg  :)
A brownstone would be pretty. . . .
I clicked on the link and got an Access Forbidden  response. It must be a really awful picture! :D
46 minutes ago, Debsrand56 said:
Oh, no!  Maybe if you try here:   https://www.rocknrollbride.com/2014/05/honeymoon-travel-guide-san-francisco/   You'll need to scroll down a bit, but you'll know it when you see it.
That did the trick ... wowsers! I hope the inside isn't anything like the outside.
<Glad the computer is not in the same room as the Beacon Hill or who knows what she might get in her head!>
1 person likes this
LOL! That's too funny! I understand though. I've gotten almost finished with a house only to have it tell me it wants something totally different...
Followers 0
  • Similar Content
    • Need info
      By Jesseblues89
      I have recently acquired a amazingly beautiful doll house for FREE, hard to believe, but it's true. There are a few cosmetic issues on the exterior that need replaced and/or fixed: The entire porch railing. Most of the clear plastic window backings are missing. Doors need it be replaced. Trim work needs to be replaced, and from what I can tell, a balcony/walkway of some sort existed above thw3rd floor window and wrapped around  both sides of the house. I want to restore & repair it to prime condition & do it correctly.
      I was never lucky enough as a child to have one of my own. So this is a very special project for me to say the least, lol.
      I have no information on it what so ever & would really like to figure a few things out about it, if possible:
      ¹What particular kind of doll house it? ²How old is it? ³What can be DIY/hand-made instead of buying expensive pre-made kits, like porch railing, banisters ect? ⁴Is it possible to add a balcony to the 2nd or 3rd floor? ⁵Is it possible to modify an existing window into a doorway? ⁶Is it possible to add/remove interior walls to make rooms/areas bigger/smaller? ⁷Can a door be added to an existing interior wall? ⁸Can a 2nd door leading to the porch be added on the side of the house?
      I have no clue and figured the best thing to do was ask.
      ANY tips & advice on the best way to go about any of this would be greatly appreciated!
      My ultimate goal is to completely restore & repair the entire doll house top to bottom.
    • Hurstwood Cottage Kitbash
      By worldofcrazies
      Hi,
      I've introduced myself in the newcomers forum.
      I received my Hurstwood Cottage kit from Bromley yesterday and I've already started on it.
      Here's an album of me unpacking it: https//imgur.com/a/1ITiW6m
      This is an intro post basically. This is my first dollhouse build so I thought I'd go for a small one and my plan for this also includes doing three different types of exterior finish; brick, panelling and render.
      I'm going to turn this into a nice modern home.
    • Greenleaf Products, plus some questions
      By Kells
      It finally occurred to me that I'm on a Greenleaf forum and I have never shared that Greenleaf has one of my favorite and most used products, but I'll get to that last. First a couple of questions.
      Is anyone familiar with Greenleaf's vinyl tile flooring? Is it glossy, and if so, can it be dulled? I want a paved stone look throughout the entire first floor of my Creole plantation house. This product:
      https://shop.greenleafdollhouses.com/miniature-scale-vinyl-floor-tiles-grey/
      While I can do the paperclay method, I'm worried that is going to add a great deal of weight to an already very heavy house. It's Lawbre's Rosedawn and it weighs a lot even in its unfinished state.
      Added weight brings up my other question. Can anyone recommend a good brick sheet? Something textured, embossed, with the appearance of real brick? I've in the past purchased a few printed sheets of brick from England just to see what they were like and, well, I'd use them on a child's dollhouse maybe but not something on which I'm going for realism. They look good but even when not up close they are very obviously just printed paper.
      I've etched brick into joint compound (a lot of work but looks great!). I've done brick and stone out of egg cartons (also looks great!). The joint compound will make this house far too heavy, and there is no way in heck I am cutting thousands of individual bricks out of egg cartons! I am seriously hoping there's some product out there that would work.
      Okay, so there are my questions, now allow me to sing Greenleaf's praises for one of their products that is one of my favorites and most used. Their siding:
      https://shop.greenleafdollhouses.com/miniature-clapboard-siding/
      OMG have I bought bags and bags of this stuff over the years. It's admittedly a bit rough and I probably wouldn't use it to side a gleaming mansion, but it has so many other uses! Here are some that I've used it for.
      It's perfect for siding a farmhouse or other "rustic" building. A simple wash gives it a fantastic aged appearance without a ton of work futzing around with multi-layers of painting and sanding and aging techniques. Some awful blurry old pics below of my farmhouse when it was in progress. I don't think they show just how fantastic that siding looked IRL.
      Another pic below is a pic of a bedroom in (I think) Salem, MA. See that ceiling and that planked wall behind the bed? I used Greenleaf siding to recreate that and I was totally thrilled with the result. I also used Greenleaf's shingles on that same Colonial. The front was clapboard but I shingled the sides. I needed smaller shingles because historically those were pretty narrow. I simply snapped 'em in half, no scoring required.
      The first floor of my Creole is going to be pretty "raw", with exposed brick exterior walls, but the interior walls of the first floor will be exposed planks behind stud framing. I'll be using even more Greenleaf siding for that. It's 3/4" wide so I'm going to score it at 1/2". The half-inch planks will be for the wall framing, the remaining 1/4" will be the equivalent of 3" lathing for the attic ceilings. And, of course, loads of it to plank almost all of the ceilings!
      So there are a few of my handy-dandy uses. And at $5.00 for 360 square inches, I challenge anyone to find a better deal! If you could even find something that works half as well. Do you have other-than-intended uses for the siding or other products?
      Edit: And oh yeah, it worked fabulously well for horizontal planked wainscoting in that Colonial house. I was going for a very early Colonial look so I didn't want any fine mouldings. That siding did the trick!
    • I finally figured it out!
      By hmayonayz
      I finally got it! I'm building my first house, the Orchid.  I literally sat and stressed for hours yesterday about the stairs, which were horrible and splintery and way too big really for the housel. So I found angieaug's video on youtube and the lightbulb went on. I cobbled together a set this morning that fits like I want and she made it easy as pie. Eating pie that is, lol. So thanks to her! They are drying but I need to figure out wallpaper and stuff before I put them in permanently.
    • New from Madison, Wisconsin
      By gimpnelly
      Hi there! I just purchased an Orchid kit that I’m very excited to build and wanted to join this community to chat about it! I have one unfinished dollhouse that’s just too big for my current home (it’s 32” wide and I needed something smaller), so I decided to start over again. By day, I’m in marketing and I live with my fiancé and our two cats in Madison. I also like to read, write, play video games, watch TV, and see live music. Nice to meet you all!
