Sign in to follow this
Followers
0
19 posts in this topic
Followers
0
Recently Browsing 0 members
Similar Content
Hello from Rhode Island
By LittleHouse
Hello! I'm new here. Some things about me:
I have always loved miniatures. As a child, I had a large Ginny doll collection, a treasured dollhouse baby from Germany, and lots of little plastic dolls from the dime store. When I learned to read, “The Raggetty Paggetty Dollhouse” and The Borrowers were favorites. This is my first dollhouse. I’ve come close to buying one many times, but nothing was ever quite right. Then I saw The Fairfield! It was love at first sight. I like the way its rooms are at angles and not just a set of boxes lined up in a row.
I’ve already been browsing the posts of Fairfield builders on the forums. I love the suggestions and advice and seeing all the different ways of doing things. So far I’ve made the base and the staircase and done LOTS of dry fitting. I hope to use what I’ve read to make my first dollhouse a good one, but I hesitate to take a step that can't be undone! Sometimes I think: Hmmmnm there may be something to be said for those houses that look like a set of boxes lined up in a row ;-)
Linda
Hello from Orlando, FL
By petiteprovisionsco
Hello, everyone! My name is Erika and I'm a miniaturist living in Orlando, FL. I've been making miniatures for about two years now (I specialize in food and home/holiday decor), but I just acquired my first dollhouse (a fixer upper) and thought this would be the perfect place to learn and share throughout the process of rehabbing it.
When I'm able to post photos, I may need the benefit of your collective wisdom to help me identify the house. I purchased it off Facebook marketplace from someone who didn't really know anything about it. Based on the instructions and printed materials that came with it, I'm estimating that it's from the 1970s. It appears to be a Real Good Toys model called Fox Hollow, but my research on that name didn't turn up much of anything useful.
Anyhow, it needs quite a bit of work, but I'm really excited about the prospect. I'm planning to start my renovations on the exterior before moving inside. It needs repainting - especially the porch, which is blue and not really the look I'm going for - and the clapboard siding is warped in several places, so I'm not sure if I'm going to replace it all or just try to fix the sections that are damaged.
I've been reading quite a bit here in the forums over the past week or so and am looking forward to learning more from all of you!
Best,
Erika
My first dollhouse AND rehab
By allucht03
Hello all! I picked up this "less than beautiful" dollhouse for $65 and am redoing it. Any suggestions on what to do design wise? Craft wise? Technique wise? This is my first dollhouse and I want to make the effort as painless as possible!
P.S, if anyone knows what the name/manufacturer of this dollhouse is, that'd be great! I believe it's a kit, because it has pegs/holes for many of the pieces that go together.
Taking apart hot glue
By PipPoopPeeps
Any tips for dismantling a dollhouse put together with hot glue? I don’t want to take apart the whole thing as it’s very stable. It was assembled 25 years ago and is holding together really well, I want to re-do the windows and put on siding so I just want to remove windows, trim and porch railings. I’m nervous to use a hairdryer in case I loosen things I want to keep intact. Anyone with experience taking hot glued dollhouses apart?
New to Miniatures
By InfamousZim
Hello everyone! As the title states I am new to this, but I have just purchased a partially finished Victoria’s Farmhouse. It’s basically a shell.
However, I have lots of questions!
•What tools should I get and invest in? Are there ones you wish you had when you were starting or one you can’t live with out?
•The dollhouse is missing a piece! What should I do, is there a way to get a replacement?
•The walls were not glued flush. There are gaps in a couple of places and the piece that is missing wouldn’t set flush if I had it because the roof would but up against it. There is one that is not glued on one side. How can I fix these?
•The entire outside is pairing a deep blue with bright trim. What is the best way to paint over it. I want white trim with a lighter exterior color.
•All the dowels and railing pieces are painted as well. Would it be best to sand and repaint or buy new dowels. There are over 150 pieces that are painted, mostly dowels.
Any help or resources would be appreciated!
I am trying to figure out how to post pictures but they are all to big. Any help there would be great as well!
Thanks,
