WC Posted January 4, 2020 Share Posted January 4, 2020 I bought an Orchid kit from Hobby Lobby some time last year - can't remember exactly when. I have the foundation, the walls, and both floors glued in and was getting ready to put in the partition walls when I realized that the partition walls are badly warped and then I discovered the main floor is now warped. I am assuming that the only way to work on the main floor is to totally disassemble the whole house. I glued it with Aleene's tacky glue. Is there any way to take it apart now ? If I get it apart, do I just soak the warped pieces and weigh them down ? For how long? What's even more discouraging is I bought another Orchid kit (also from Hobby Lobby) just before Christmas and have discovered that it also has warped walls and floor. Any suggestions ? Quote Link to comment Share on other sites More sharing options...
havanaholly Posted January 4, 2020 Share Posted January 4, 2020 For the unassembled kit store it flat with evenly distributed weight on top and see if that helps with the warp. When you get your present kit disassembled you do not need to soak the pieces, just dampen them and lay them flat under evenly distributed weight (old textbooks are great for this, or paint cans on top of scrap boards) until they dry. If you live in a very humid climate you might invest in a room dehumidifier for your work area. Quote Link to comment Share on other sites More sharing options...
Khadi Posted January 4, 2020 Share Posted January 4, 2020 You can disassemble using a hair dryer to heat and soften the glue. Then follow Holly's directions. Quote Link to comment Share on other sites More sharing options...
