my mini telescope
48 posts in this topic
Hey all...I know I'm new to the sight, but I thought I would share my idea with you all. (hope all the photos come out with this)
I am currently building the Orchid and want it in a Nautical theme...so in my searches,
I found a site that had a telescope on a tripod for $110.00...uh-huh... :) Well, not having the last name of Rockefeller or Gates, I decided...what do I have laying around that I might just try to make my own.
So, I first found a Crayola black colored pencil...said right diameter to me, so I cut a piece off about
1-3/8" and sanded the cut end flat, then I found some Avery Notarial Seals that I had laying around
for who knows how long, and said hmmm...adhesive backing, that could work for imitation brass parts.
Then I needed something small for the brass piece above the main telescope, so I thought a toothpick piece covered with the Avery gold again, and for the wider rim at end, I just added another smaller width of Avery gold again, wrapping it around twice. The piece that holds smaller scope up is also
very small piece of toothpick wrapped in gold again. I did have to use instant glue to get ends to seal
because the adhesive gets dirty very quickly on pcs. this small (and my fingers got glued as well :wave: B) ) The Insta-Set works great for these really small pcs. - helps instant glue seal
even more quickly so I didn't have to let fingers set to the piece (Thank God!!) lol Glue smallest piece to top of telescope about 3/4 of the way back, then glue small scope to top of that.
My next find was purely coincidence...I had purchased a set of 2 door knobs/plates with keys for my Orchid, and the keys were just hanging about (lol), so I bent them a bit and thought they could be used for attaching the piece legs would adjoin to. (in my pic's I have substituted what I think will work- a cheap gold earring I had from WalMart, just cut with good sharp clippers) Now to find the piece legs adjoin to....
Having a huge bag of misc. gold buttons from Michael's (plastic and metal for about $4), I found a
plastic button with right shape (plastic is important as you will have to sand top of loop flat so it can adhere to bottom of telescope), so I sanded it a bit (by the way, I used drywall sandpaper and laid it flat on my work space...a couple swipes in same direction did it) then I glued that piece to the bottom of telescope directly under the top scope already in place. I then took the bent keys (refer to "earring " I swapped in this, as I did not have more keys laying about) and glued them on either side of telescope and to button ( I had to use angled tweezers for this as glue set up quick)
Now you should have main piece of telescope...on to the tripod :p
I had 1/8" balsa laying around, so I cut (3) 3-1/2" pcs. ( you may want to have your scope sit higher, and since it was first attempt for me, I guessed..I think my Orchid owners are short!!LOL) Lightly sand the edges to a somewhat rounded shape on top and just lightly sand rest to your preference. Cut off about 1/8" from ONE PIECE ONLY...this piece will be used at the back of tripod and will make telescope
sit at an angle. Stain the balsa pieces or paint - your choice.
Lightly sand top of each leg to a slight angle so it will adhere with the glue to edge of button bottom.
Glue shorter leg in place (to button rim) directly lined up with eyepiece at back of telescope. Then glue the other legs evenly spaced at front end of telescope. Test that it sits straight, adjust if needed by sanding a bit LIGHTLY.
Then I found an old "real cheap necklace" piece I had - think it came with a WalMart blouse I got..LOL
so it cut it into 3 pcs about 1-1/2" long each. (mine had the little "fish like thing at bottom you see in the finished photo, hanging in middle of telesope structure, which I just added for more fun)
I then took straight pins and in end link of each short chain, I put pin through last link, pushed pin thru the balsa till head of pin and chain met the balsa, hit with crazy glue, then Insta set. Now take the other end of chain, decide how you like it to hang, push pin through that link (cut off any remaining links after gluing) and push through next balsa leg..glue with crazy glue. Take small wire cutter and cut off the pin ends as close as possible. Repeat process through next 2 legs. Add the funny "fish" thing if you have it, or not....was just lying there and I never seem to call it "finished....LOL
Hope my instructions are clear...heaven knows, its so hard for me to translate what my brain does :doh: And feel like I just wrote War and Peace...holy moly...anyway, hope this helps someone, and hope the pictures make my cobweb-cluttered brain instructions easier. Let me know what ya think...
Chris, I think you are extremely talented and I hope to see more of your tutorials. Very easy to follow and your results are amazing. Thanks for sharing!!!! :)
wow, I'm impressed! Really one of the best homemade minis I've seen!!
WOW!! That is so cool. It's great to see that kind of thinking.
WOW, anymore of your fantastic tutorials? You go girl cause you are good.
Debbie
Awesome, Chris! Mega thanks for the tutorial, you are GOOD!
Thanks so much all for positive response...I was pretty happy with it, .
It's so hard for me to "throw stuff out there", but you have all been so kind, and
Nothing ventured, nothing gained. So I threw it in...lol
Thanks so much for letting me share and be a part. This is such a great forum :)
Wow, what an Amazing Telescope you made! Thanks for the tutorial too!
I added it to our tutorial area in the General Mini area. Thanks!!
Tracy,
Thanks for adding to tutorial...hope it helps someone
I just thought 110.00 was crazy....I could buy new DH for that...have my eye on the Westville...
of couse will have to keep hubby in dark (like a mushroom)...which he should be used to by now...LOL
Oh, btw, you had asked...I live in Wonder Lake...not sure how far that is from you...but I am bout 15 minutes from Wisc. border. Anywhere near Lake Geneva?
I am 15 minutes from Great America. I am around Kenosha :wave: . How cool to find another mini person around here :)
It's wonderful! So cool to see something life size and turn it into a mini! Thanks for sharing the tutorial!
Wow!! That is great. I've been thinking about looking for a telescope for a roombox idea I have. Maybe I'll try it. Thanks for the tutorial!!
Tracy, I meant to ask....checked your website...your houses are absolutely AWESOME!!!
I am always amazed by detail, and you certainly are into detail....and do it so very well!!!!
KUDOS!!!
But really, I had meant to ask, when looking at your web, I noticed you had been to Colleen Moore's Dollhouse...just wondering, did you get the chance to see the Thorne Rooms too?.....68 rooms of pure pleasure for any miniature people. I myself could stand there all day!!! lazy me...lol I discovered those too as a little girl who thought the castle was the best thing, then I found the "rooms""...WOW
Awsome work, I have an old fashioned camera that is missing it's tripod, this should be perfect. TRhanks for doing the work and posting the instructions.
That is so cool, and so easy to follow!! I was wondering if a telescope could be used in a lighthouse? My latest "Baby", is a 1/2 inch one.
And I'm still almost clueless on furnishing and decor. Thanks for sharing!
<standing and applauding> That is an *awesome* bit of work! I absolutely, totally am in love with it and can't wait to try making one! Thank you soooooooooo much for sharing the tutorial with us!
Deb
Just me:
I would think so..you would just need to scale it down...maybe an old tube from an ink pen painted black - also, many spray cans now come with an aerosol tube attachment...perhaps one of those would be of the right size. ...just ideas...hope you can find stuff that works in your size....not really sure how small 1/2" scale is...
I would think all other stuff should work, provided you could find smaller scale button and very fine chain links. Good Luck and happy crafting.....
Fantastic job...you can hardly tell the difference between the $110 model and your copy of it...Thanks for sharing! Very inspiring!
