Wood fillter vs. Spackle
  • Please log in to reply
7 replies to this topic
#1 eglefther
eglefther
    Member
  • Gold Member
  • 541 posts
  • Joined 28-July 08
  • Local time: 05:51 AM
  • Gender:Female
  • Real Name:Shar
Posted 25 August 2008 - 05:46 PM
Being new to the woodworking hobby I need to know the difference between the two. Is the difference the amount of fill needed? or whether you are painting vs. staining? or are they interchangable?
EagleFeather...aka Shar
#2 grazhina
grazhina
    Member
  • Platinum Member
  • 2666 posts
  • Joined 26-July 05
  • Local time: 08:51 AM
  • Gender:Female
Posted 25 August 2008 - 06:00 PM
wood filler is another name for wood putty, which is used to fill gaps and holes in wood. Spackle is primarily for repairing holes and cracks in plaster, however, if you're planning on painting the wood, you can use spackle too. It can actually give you a smoother finish.
If you plan on staining the wood, stay away from spackle. Wood filler or putty doesn't take stain well, though there are stainable wood fillers. In the past, when I needed to stain wood putty, I'd sometimes give just the puttied area a light coat of paint that matched the stain.
I used to be indecisive, but now I'm not so sure... :fish1:
New England Miniatures
Victorian Interiors & More
Colonial America: The Simple Life
#3 Wolfie
Wolfie
    Wolfie
  • Platinum Member
  • 10579 posts
  • Joined 15-February 07
  • Gender:Female
  • Real Name:Wolfie
Posted 25 August 2008 - 06:05 PM
She has said it all......that's about it! I'm a stucco person myself, which is rough like paster, not to be used as wood filler.....
Wolfie
http://www.lonewolfm...recreations.com
"Bringing little people to life - one little person at a time!
#4 uppitycats
uppitycats
    uppitycats
  • Platinum Member
  • 4156 posts
  • Joined 28-May 05
  • Local time: 07:51 AM
  • Gender:Female
  • Real Name:Ann
Posted 25 August 2008 - 06:39 PM
I think stucco is more like spackle. I've come to love spackle. It hides a multitude of flaws, is easy to paint over, and leaves a real "finished" look to the house.
I think each has it's place, for sure. For me, it's not like I'll stop using wood putty, especially since I learned about all the different colors it comes in, and in neat squeezable tubes.. But it seems like the spackle is more versatile.
#5 Lisa R.
Lisa R.
    Member
  • Gold Member
  • 883 posts
  • Joined 27-January 07
  • Gender:Female
  • Real Name:Lisa
Posted 25 August 2008 - 06:48 PM
I like wood filler alot. I use a minwax filler and it has proven very stainable. In fact I like it so much I'm wondering if it would be better than grout to use as grout. I will be attaching cut stone veneer made from high density plaster to the outside of a plywood house. I thought that wood filler might be better than grout or spackling between the stone ... but I'm still wondering!
Lisa R.
#6 eglefther
eglefther
    Member
  • Gold Member
  • 541 posts
  • Joined 28-July 08
  • Gender:Female
  • Real Name:Shar
Posted 25 August 2008 - 07:16 PM
Thanks for the info!!!
#7 havanaholly
havanaholly
    Cousin Farfrom Normal, Queen of Spackle
  • Team Master Builder
  • 57052 posts
  • Joined 23-March 05
  • Gender:Female
  • Real Name:holly
Posted 25 August 2008 - 10:43 PM
Spackling compound is used in RL to smooth flaws in drywall & plaster. It can be used in mini to simulate plaster, stucco, stone, brick, etc. It's lovely to paint over.
Wood filler can be made from glue and sawdust and minute amounts of stain to match the wood finish you're trying to fill and sands nicely. I have never found a woodputty I was happy with either its sanding or staining properties.
IMO I wouldn't use either one if I want to use stain.
havanaholly
working as little as possible
#8 chesterfieldzoo
chesterfieldzoo
    Member
  • Platinum Member
  • 9426 posts
  • Joined 07-October 06
  • Gender:Female
  • Real Name:Deana
Posted 26 August 2008 - 09:05 PM
Stucco, spackle and plaster are all the same thing, just slightly different densities. I don't use them as gap fillers in wood, but I will use it to fill imperfections in wood that I am going to paint. I will also use it if I neglected to sand enough and the wood is slightly grainy. (Drag a putty knife of plaster across the grain and a quick sand by hand)
Wood fill is good for gaps if walls don't fit tight (or floors).
~*~ A rich person is not the one who has the most...but the one who needs the least. ~*~
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
