Step-by-Step Directions for first time builders?
  • Please log in to reply
36 replies to this topic
#1 debramt
debramt
    Member
  • Silver Member
  • 10 posts
  • Joined 09-November 11
  • Local time: 02:53 AM
  • Gender:Female
  • Real Name:Debra
Posted 29 November 2011 - 09:10 PM
Thanks to all of you, Terry and I made the decision to go forward with the GL Laser Cut Beaumont (our first dollhouse project). I've learned much from all the forum comments and suggestions, but wondered if there's a step-by-step guide, Youtube video or reference, that explains each sequential step for building a dollhouse (based on all your best practices and lessons learned), for example:
  • Open your new box and locate all the house components and label each by....,
  • Read the instructions several times so you're comfortable with the building plan,
  • Dry fit the house (using painter's tape) to ensure all parts fit together properly
  • Once built (dry fit) begin thinking about your interior design plans, i.e., paint color, wall coverings, lighting, furniture arrangements, etc.
  • and so on....
All of this may be included in the dollhouse instructions box, but not having build a dollhouse, we aren't sure.
Thanks again everyone.... we're pumped!
Debbie
#2 mininecessities
mininecessities
    Member
  • Gold Member
  • 407 posts
  • Joined 06-November 11
  • Local time: 12:53 AM
  • Gender:Female
  • Real Name:Cheryl
Posted 29 November 2011 - 10:20 PM
I am not real experienced but I would say your steps 1-5 are great! and it is good that you are asking questions. My Garfield directions just had me build the house, yes step by step BUT did not that I can recall suggest finishing off hard to get to areas, or doing the ceilings floors and wall coverings FIRST! So I ended up working two days to wallpaper the 2nd floor staircase............barely able to get my hand in there let alone move it around much lol...........it was quite a lesson. But then too I was over anxious, but it was the first kit I assembled from scatch.......my Laurel was prior built by its previous owner so I just took it apart and used different glue. My first house , all the rooms were pretty easy to get to. Congrats on your decision.....that is sometimes the hardest step.........deciding! have fun and hope to see pics as you roll along!
  • and so on....
Debbie
Currently Working On:
The Garfield by Greenleaf and Scratch built Gypsy Wagon
Still in the boxes: 2 San Franciscans, the Lafayette, and the Ashley
(all by DuraCraft.)
and now the Granville by Arply. Vintage house still in the box!
http://www.ebay.com/...&_sop=10&_rdc=1
#3 havanaholly
havanaholly
    Cousin Farfrom Normal, Queen of Spackle
  • Team Master Builder
  • 56337 posts
  • Joined 23-March 05
  • Gender:Female
  • Real Name:holly
Posted 29 November 2011 - 10:28 PM
I'm not aware of a You-Tube video, but I have posted a basic "getting started" list that you can do a search for here, that is basically what you have listed. To summarize:
Open the box, sniff and pet the wood.
Remove the instructions, the schematics sheet, the acetate sheet of window and door inserts, and the Warm-Up sheet; place the acetate inserts between the pages of the Warm-Up wheet, the basic message of the Warm Up sheet is "DON'T PANIC"
Read over the instructions. Place everything back in the box and go fix yourself a cup of hot chocolate, and start listening for the kit's voice.
The next time you open the box, set the Warm Up sheet with the acetate inserts aside, but where you can plainly see it. Read over the instructions again, using the schematics sheet to locate and identify the parts for each step. At this point I arrange all the plywood sheets into numerical order; this makes it easier for me to locate parts as I need them. (I used to remove and label the parts, but it's a whole lot easier for me to leave them in the sheets and use the schematics sheet to locate the parts; I cross them off of the instructions sheet as I put them into place).
At this point it's perfectly OK to put everything back into the box (leave the Warm Up sheet on top) and go have another cup of chocolate or a stiffer drink, perhaps.
Assemble your knife, several new, sharp blades, sanding block and sandpaper (emeryboards OK) and a roll (or two) of masking tape and start building according to the directions, sanding/ shaving your tabs & slots to get a good fit. Do NOT use any glue, this is your "dry fit". This is your opportunity to discover whether the instructions "work" for you as written, or if you need to change the order, or just ignore them altogether (probably not a good idea with the Beaumont); also, you can see what parts will be difficult to access for decoration after the build. I leave the house in dry fit as long as it takes to get it to start talking (although lately I can't shut them up as soon as the kit arrives!).
You might want to wait to install windows and doors and their trims until after the rest of the build and decoration has been done, unless you're a lot steadier of hand than I.
A gluing jig is nice to have for assembling stairs. Toothpicks are nice to have for applying glue.
If the instructions still say to seal the wood with shellac, you don't have do; clear sanding sealer works just as well for wood you aren't planning to stain or prime.
Ask questions, have fun, and enjoy the build.
havanaholly
working as little as possible
#4 debramt
debramt
    Member
  • Silver Member
  • 10 posts
  • Gender:Female
  • Real Name:Debra
Posted 22 December 2011 - 08:33 PM
Well, we've received the Beaumont box (it's big!) and set up the table for the build.
A QUESTION REGARDING TAPE: What is the optimal tape to use for the Dry Fit (characteristics offering good adhesive and reside-free). I'm thinking '3M Scotch Painters Blue Tape". What's everyone using for the Dry Fit Process?
#5 KathieB
KathieB
    It's the little things that count
  • Platinum Member
  • 15063 posts
  • Joined 30-July 06
  • Gender:Female
  • Real Name:Kathie
Posted 22 December 2011 - 09:01 PM
Masking tape, blue painter's tape, green painter's tape ... whatever's cheapest. It doesn't need to hold forever and won't be on long enough to worry about residue.
#6 havanaholly
havanaholly
  • 56337 posts
  • Gender:Female
  • Real Name:holly
Posted 22 December 2011 - 09:03 PM
What Kathie said.
havanaholly
#7 debramt
debramt
    Member
  • Silver Member
  • 10 posts
  • Gender:Female
  • Real Name:Debra
Posted 22 December 2011 - 09:19 PM
Thanks for the quick response.... I have some painter's tape from a recent project so I can begin assembling in a few days.
#8 jbnmini
jbnmini
    Member
  • Platinum Member
  • 1058 posts
  • Joined 11-February 10
  • Local time: 03:53 AM
  • Gender:Female
  • Real Name:Jackie
Posted 23 December 2011 - 10:18 AM
LOL I like Holly's step-by-step instructions.... :giggle: Gonna remember them for the next kit.
"It is better to be silent and thought a fool, than to open your mouth and remove all doubt." :zipped:
Currently working on rehab of the Ellwanger House (a special edition RGT North Park)
Waiting in the wings: Artply Highland, Artply Barrington, DC Bellingham Farmhouse, GL Jefferson, the Pepperwood Farmhouse and a Scratch-Built Log Cabin
#9 debramt
debramt
    Member
  • Silver Member
  • 10 posts
  • Gender:Female
  • Real Name:Debra
Posted 23 December 2011 - 05:59 PM
After opening the Beaumont Box, all parts were included except for the Warm Up Sheet. Does anyone have access to the Warm Up Sheet and could scan/ email us a copy?
thanks,
deb
Edited by debramt, 23 December 2011 - 06:00 PM.
#10 havanaholly
havanaholly
  • 56337 posts
  • Gender:Female
  • Real Name:holly
Posted 23 December 2011 - 09:16 PM
You can certainly use one of the slick paper newspaper ad inserts to keep your acetate insert sheets safe from scratching/ damage. The Warm Up sheet gives a basic list of what you need (you can also figure that out from the instructions & the dry fit), and the best info it has is these words I'm giving you right now: Don't panic!
havanaholly
#11 labrown
labrown
    Member
  • Gold Member
  • 183 posts
  • Joined 27-December 09
Posted 24 December 2011 - 06:24 AM
When you get started dry-fitting have LOTS of what ever tape you are going to use. I try to keep 2-3 rolls of different widths -- at least when my dogs don't come steal it -- don't know why but they love to grab it if it falls on the floor--and it's not easy trying to pull off a piece with bite marks in the roll. But I do use tons of that stuff all through the building process.
Just have fun with your first one and remember that there is nothing you can't fix even if it means taking apart and starting over. For me it's not a race to the finish, it's the journey along the way,
Lu Ann
#12 havanaholly
havanaholly
  • 56337 posts
  • Gender:Female
  • Real Name:holly
Posted 24 December 2011 - 09:11 AM
Years ago I invested in a self-healing cutting mat and I keep LOTS of waxed paper on hand, and when I need narrow strips of masking tape (like for door & window trim, wanting to glue bare wood to bare wood) I lay strips of tape onto sheets of waxed paper, mark the intervals down both ends for the narrower widths I want, and use my corkbacked steel straight edge and a brand new blade in my utility knife to cut narrower widths of tape. It peels right off of the waxed paper, with just as much stickum as usual.
  • Sears likes this
havanaholly
#13 fov
fov
    Moderator
  • Super Moderator
  • 3245 posts
  • Gender:Female
  • Real Name:Emily
Posted 26 December 2011 - 03:02 PM
You'll find the warm-up sheet here (it's also stickied at the top of the Question about a Particular House / Greenleaf Dollhouses forum). Make sure to click the green Download button to download it; the thumbnail version that displays on that page is too small to read.
I haven't read this lately and am not sure if it applies entirely to laser cut houses (might have instructions about sanding, etc.) But this file should give you the gist of it.
#14 Mandystar
Mandystar
    Living life and loving it!
  • Banned
  • 570 posts
  • Joined 01-August 11
  • Gender:Female
  • Real Name:Sandy
Posted 27 December 2011 - 11:51 AM
Oh, Debra, what you are experiencing right now is the best part of building a dollhouse!!!
Yeah -- I mean the head-scratching, planning, dry-fitting, "what the heck am I supposed to do now" parts!!! It's just like having a HUGE 3-D jigsaw puzzle where the picture on the box is only a suggestion! Certain steps (like dry fitting each section) are really important, but I'd go along with Holly's recipe in a heart beat!
Lu Ann said it in a nutshell...Enjoy the journey!
<em class='bbc'><span class='bbc_underline'>Still don't know what I want to be when I grow up!</span></em>
#15 havanaholly
havanaholly
  • 56337 posts
  • Gender:Female
  • Real Name:holly
Posted 27 December 2011 - 12:08 PM
Do the lasercut kits have a warmup shhet? I don't remember one with my 1:24 Lighthouse...
havanaholly
#16 SallyG
SallyG
    Member
  • Platinum Member
  • 1015 posts
  • Joined 17-July 06
  • Gender:Female
  • Real Name:Sally
Posted 27 December 2011 - 01:19 PM
Ahh..the laser-cut Beaumont!!! Laser cut....ahhh! You are lucky to be doing laser cut and not the die-cut..I'm working on the Fairfield and am back in my old sanding mode...the laser cut Rosedale spoiled me!! The only thing I can add is to know exactly how each room will be painted/papered and decorated. Do as much as possible before you glue the house together, being careful of matching up corners, etc. Plan your flooring also. I generally have 90% of the house interior completed when I finally glue it together!
#17 Mandystar
Mandystar
  • Banned
  • 570 posts
  • Gender:Female
  • Real Name:Sandy
Posted 27 December 2011 - 01:41 PM
Hi Sally,
Nice to meet a neighbor! I think the prep work that you are talking about applies to both... laser-cut or dye-cut houses. I'm so pleased with myself that I thought that bit out before starting on my first house -- especially after reading all the horror stories about trying to get in to wallpaper (or whatever) all those impossible-to-get-to places!
#18 SallyG
SallyG
    Member
  • Platinum Member
  • 1015 posts
  • Joined 17-July 06
  • Gender:Female
  • Real Name:Sally
Posted 28 December 2011 - 11:37 AM
Hi Sally,
Ah, Mandy...Delray! I'm in Lake Worth. I come down to Delray once in a while to the dollhouse shop! I have to make a trip down there soon for some half-scale things! And yes, the prep applies to both. It makes life a LOT easier!
#19 Mandystar
Mandystar
  • Banned
  • 570 posts
  • Gender:Female
  • Real Name:Sandy
Posted 28 December 2011 - 12:02 PM
Oh, yes. I've been to that shop so many times! I probably paid their rent for a few months back when I first got started! Let me know when you plan to go next -- don't wait too long because their stock is getting pretty low. You do know that they're closing in March, right?
#20 havanaholly
havanaholly
  • 56337 posts
  • Gender:Female
  • Real Name:holly
Posted 28 December 2011 - 08:57 PM
Sally & Sandy, I grew up three blocks north of Forest Hill Blvd in West Palm Beach.
havanaholly
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
