Printable Shingles
  • Please log in to reply
4 replies to this topic
#1 F4vrYoung
F4vrYoung
    Member
  • Gold Member
  • 62 posts
  • Joined 09-April 07
  • Local time: 04:56 AM
  • Gender:Female
  • Real Name:Jill
Posted 26 August 2007 - 10:34 PM
Does any one know of a place to download printable shingles?
#2 justmesue
justmesue
    Member
  • Platinum Member
  • 7262 posts
  • Joined 10-March 07
  • Local time: 06:56 AM
  • Gender:Female
  • Real Name:SUZANNE
Posted 26 August 2007 - 11:13 PM
I don't know of a place to print shingles. I'm assuming however, that you'd like to make your own out of cardboard? If you were to cut out, a bunch of equal size rectangles, on cardstock, or heavy bristle board , and glue them in shingle manner, I see no reason, it wouldn't work. Remember to stagger them, and keep the same overlap. The size for rectangular shingles is 1 and 1/2 inch long by 3/4 inch wide. Hope this helps.
SUE
#3 Anna
Anna
    The thrifty witch
  • Platinum Member
  • 12113 posts
  • Joined 29-May 05
  • Local time: 12:56 PM
  • Gender:Female
Posted 27 August 2007 - 11:55 AM
It depends on the scale you are after, Jim's printable at www.printmini.com has shingles sized fora dollhouse dollhouse so to speak :)
Hugs
Anna, http://nao-mini.com/
My Etsy shop: https://www.etsy.com...h_shop_redirect
Fairy name Gossamer Moonfly
#4 havanaholly
havanaholly
    Cousin Farfrom Normal, Queen of Spackle
  • Team Master Builder
  • 56400 posts
  • Joined 23-March 05
  • Local time: 05:56 AM
  • Gender:Female
  • Real Name:holly
Posted 27 August 2007 - 12:34 PM
If they weren't so easy to make OR if I were working in a small scale the printie shingles would work as well.
havanaholly
working as little as possible
#5 dbrazelt
dbrazelt
    Member
  • Gold Member
  • 236 posts
  • Joined 12-January 06
  • Gender:Male
  • Real Name:David Brazelton
Posted 27 August 2007 - 05:19 PM
If this is for your Special House project, I think that you can make the proper shingles easily yourself.
I use either sandpaper or craft paper and cut a strip of the width for the scale (1 inch for 1"=1'; 1/2 inch for 1/2"=1'; and so forth on down the scale. (By the way, rarely will this come out even with the paper you are using. Don't throw away the scrapped strips) I take the strips several at a time and use paper clamps (paperclips will work but not as well) to hold them as I uss scissors to cut slices about 3/4 way thru. This is a time you can sit back, watch TV and cut shingle strips.
When you have enough, then you can start at the bottom of the roof. First, lay a strip of the discards from above (I told you not to throw them away) at the bottom of the roof. Next, run a line of glue just above them and one at the first line you should have drawn before this all started.
Dave GSOLFOT
www.homestead.com/davesminiplace
dbrazelt@tampabay.rr.com
Have a great day!!
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
